DIY Power Cable
0 Members and 1 Guest are viewing this topic. Read 1859 times.
Escott1377
DIY Power Cable
« on: 15 Jun 2015, 01:41 am »
I am considering making some power cords for myself using 10 / 3 unshielded cable.
When complete, I only plan on using on my power and tube amps, not for any source components.
Can I float the ground and still be OK - to avoid any ground hum issues?
Essentially, not connect the ground on the IEC end.
Thanks in advance for any feedback.
Eric
Occam
Re: DIY Power Cable
« Reply #1 on: 15 Jun 2015, 11:58 am »
You are considering purposefully removing a required safety feature from your electrical system connecting a component?
At best, in the event of an electrical fire, your property insurance will deny coverage. (even if not the actual cause, just as an excuse). At worst, you'll kill someone by bypassing a safety feature, and will be held civilly and criminally responsible for any damage to property and persons.
If you have a 2 pin (C18) IEC inlet on a component, you could build a cord with a fitting 3 prong IEC plug (C13) with the ground left unconnected, iff you fill the IEC plug's safety ground opening with epoxy, making it a C17 plug, so it wont fit in a 3 blade IEC inlet.
« Last Edit: 15 Jun 2015, 01:23 pm by Occam »
Escott1377
Re: DIY Power Cable
« Reply #2 on: 15 Jun 2015, 10:16 pm »
Roger that.
