I recall one AC'er raving about a fairly cheap Yamaha sub, but I can't think of any under-$400 sub you'd want (DIY models excepted)
Quote I recall one AC'er raving about a fairly cheap Yamaha sub, but I can't think of any under-$400 sub you'd want (DIY models excepted)I believe that was audiojerry....might send him a PM for info. [/list:u]
...Then again, every setup is application specific and subs like the VMPS Larger do not fit the bill with my mini-monitors. I *consciously* sacrificed the lowermost octave in favor of ensuring seamless integration. That's why knowledge is necessary. As long as the choices made are conscious, then there's no problem--you're aware of what you're doing...
why i know room size is key: even tho i have never heard psychic's modwright-tweeked swan m1 mini-monitors, i am sure they would work *perfectly*, w/seamless integration with vmps larger subs - in a room sized as mine was. why do i say this? cuz i had in my rig a pair of proac tablette 8 reference signatures - at 10.5"h x 6'w x 9"d, w/4.5" woofers, and 86db efficient, these things *rocked* in that same room, when crossed over to the subs at 70hz... the sound was fantastic - almost up to the meret re's shown in the pics. in fact, some folk mite prefer the proac's; it's a matter of taste, imo. i certainly could have lived with them long-term. ...
I knew *ewe* would say that. However, seamless integration is more than just being able to slope both ways evenly. The damping pots are crucial in making the depth and energy of the soundstage match. The tonality and speed of the woofers/sub cones must match, as well as the amps'. My setup was truly invisible. The NHT's go higher--and faster--than the VMPS. In my setup passive radiators wouldn't do it. The NHT's have the woofers off center, unlike the VMPS. That avoids standing waves and unwanted r ...
