Headphone Stand Lovers and PICS Thread: ALL Stands Welcome!!
0 Members and 1 Guest are viewing this topic. Read 16489 times.
Letitroll98
  • Too loud is just right
I love it FRM.  I wonder if there's some made with heavier material than Styrofoam.  So I checked real quick on eBay and it looks like there are several variations, some with bases that might work better as headphone stands, but the idea is still great.
OK this stand will outbest the Milford screw.
This is a real Stand for $2,50 only, and you can exercise your painter skills and color it to your liking with crayons from yours children.
http://www.ebay.com/itm/Female-Styrofoam-Mannequin-Manikin-Head-Model-Foam-Wig-Hair-Hat-Glasses-Display-/391181469055?tfrom=270959618684&tpos=top&ttype=price&talgo=undefined
R_burke
You can usually find these on Ebay do a search for glass mannequin heads
Blu99Zoomer
I would be curious to know if those glass models are certified Memorex safe in case one were to hit the play button on the reel to reel by mistake with the headphones on the manikin ...;)
Blu99Zoomer
krikor
  • Initiative comes to those who wait.
    • AudioSnoop.com
Available at Pier1 for $20. Put a small light inside perhaps?
Letitroll98
I'm headed for Pier One then.  Thanks.
brooklyn
DIY Headphone Stand
Guy 13
DIY Headphone Stand
Hi brooklyn,
I like your headphone stand,
simple to make and inexpensive,
but I would stain it a more or less dark(er) color.
Guy 13
dB Cooper
I got this holder with my $80+/- Sennheiser 485's. My $500 HD650's came with... a nice box. Go figure. Anyway, this one (which Senn sells separately for $29 last time I checked) holds my 650's just fine. C&C
Search Amazon for 'banana holder' and you'll find some other good improvised holders.
Here's a nice one for $16.99:
http://www.amazon.com/Stylish-Acrylic-Headphone-Cleaning-Hangers/dp/B00NOBXBVC/ref=pd_sim_107_2?ie=UTF8&dpID=51HYLyqa0qL&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=1T9Q7DGXD1NM1CY2F9YM
I'm working on stands for my IEM's made out of paper clips  :lol:
dB Cooper
(deleted)
timind
  • permanent vacation
Mine is a door stop screwed into the side of the night stand. Simple and effective.
Guy 13
Hi timid,
cheaper (Read : Inexpensive) than that...
You put down the headphones directly on the desk.  :lol:
Guy 13
I've got the same headphones HD650  :thumb:)
brooklyn
Hi brooklyn,
Guy 13
Hi Guy, I was thinking of staining it but not sure what color..
I do like the headphone holder db Cooper has and I actually had one
on my radar.. but found a few pieces of wood at work and the peg board
holder.
timind, I have to admit, the door stop is even more low tech and simple then mine.. Nice job..
L1C4
  • NOTORiOUS!
It's funny how easy banana hangers work for a while... it also really matters what the design of your headphones are... e.g. the Pyle or whatever doesn't work for ones with thin headbands and ones like the Svelking can stretch things out.
Currently my stand is it-about $1:
Armaegis
All you guys using banana hangers etc, get a pool noodle from the dollar store and cut a piece to fit over the hanger. Save yourself from those headband dents!
eclein
I finally found a cheapy one on Amazon.....plastic build for a gamer I suppose...it works.....
These are my extra cans, my Grado's stay right next to me at all times....LOL!!!!
C17FXR
  • Remember, you don't have to rewind the Blu-ray.
Not much of a stand but it keeps the big guy happy.   :duh:   :thumb:
ajzepp
Nice! Love that...are those the GS1ke, or the previous model?
C17FXR
Sorry for the late reply been rather busy the past couple weeks.
They are Grado GS1000i connected to a McCormack MID Platinum Plus.   :thumb:
They make me smile just as big.
ajzepp
Very nice...I love how the GS1ks look...beautiful headphones  :thumb:
