0 Members and 1 Guest are viewing this topic. Read 30264 times.
Rumblings now that Windows 10 support will be free for two years only. Can Microsoft figure out yet another way to screw up. Their acquisitions of Skype and Nokia were brilliant failures, now they plan to start charging consumers for security patches?????If true, it will be EASY pickings for Apple...
Found it.http://www.forbes.com/sites/gordonkelly/2015/07/10/free-windows-10-charges/Too bad the Linux community can't get it's act together and create a consumer version of Linux that could be a real alternative to Windows and OSX for the common person.
One feature of Windows 10 that I really don't like is the default automatic forced update of drivers.
You can disable automatic driver updates by Windows Update in Control Panel > System > Advanced System Settings > Hardware tab > Device Installation Settings (which is what I did) but that does disable all driver updates across the board and cannot be individually set for each hardware device.Steve
Unfortunately this feature will probably help most users that aren't technical enough to keep things up to date. But if MS doesn't do a good job of testing drivers first, people will start to hate Windows 10.
Can you disable the updates by only installing "critical" updates?
Taking Win10 for a test drive....
I absolutely hate the look of this screen shot. I have deleted every W10 "free" offer (they seem to come weekly) primarily because I am set in my ways when it comes to using computers. I resisted Office 2010 for a long time because I hated (and still do) the Ribbon. Then I found I could do a command bar like in Office 2003/2007 and hide the Ribbon and all was well again in Laura's computer world. I don't have the time or the patience to adjust to a new look of the Desktop or the various file screens. I would like faster boot times, but not at the expense of having adjust to the new looks I am seeing in this thread. I resisted W7 until they stopped supporting XP and then I made the change. I'll probably stick with W7 until they force the change and hopefully I'll be retired by then and my computer use will be pretty much limited to email and internet.
Here are a few tips to make everything go smoothly:1. Download and run the Windows 10 Media Creation Tool - use it to install or reinstall Windows 10 using a USB or DVD. https://www.microsoft.com/en-us/software-download/windows10/2. Run Windows Update to make sure everything is up to date3. Type CMD into the Start search window to get a command prompt, in the new window type "cleanmgr" without the quotes. Clean your "C" drive.4. Use the free CC cleaner to clean the registry only, the other parts clean way too aggressive for me, I want my cookies and other stuff. https://www.piriform.com/5. Download the free Paragon Backup and Recovery and image your C drive to a separate backup drive, don't forget to make a boot disk. https://www.paragon-software.com/home/br-free/6. Do a reboot7. Put in the Windows 10 disk you made and upgrade8. Uncheck everything in the 3 setup pages when asked, you can enable them later if you want9. Turn off the spy's - http://bgr.com/2015/07/31/windows-10-upgrade-download-install-tips-tricks/10. Have a beer.Wayne
