Iphone 6 digital out to Arcam D33
mr_bill
« on: 25 May 2015, 06:17 pm »
Could someone help me get digital out of my iphone 5 or 6 (lightning connector) to a DAC's  USB 2 or USB Type A digital input connector?
What do I need to buy for a connector to transfer the digital signal?
pwag
Re: Iphone 6 digital out to Arcam D33
« Reply #1 on: 25 May 2015, 07:06 pm »
You need this: Apple Lightning to USB Camera Adapter (MD821ZM/A)
About $30 at Amazon.
Austin08
« Reply #2 on: 25 May 2015, 07:42 pm »
I don't know if your dac has spdif input. If it did then using bluetooth wireless reciever. I bough the Nuforce receiver and couldn't happier.
mr_bill
« Reply #3 on: 25 May 2015, 07:47 pm »
Thanks to both of you and the blue tooth is an option too.
pwag
« Reply #4 on: 25 May 2015, 09:03 pm »
Bluetooth is a possibility and clearly more convenient than the cable, but it has lossy compression. If you stream from an iphone you can use airplay instead which streams lossless. Apple TV is cheap and has optical out. If you want to connect to your Arcam D33 with the coaxial S/PDIF input you could use an Arcam airDAC although with $700 a lot more pricey than the Apple TV.
