Pictures of my rig with Omega Speakers
saxguy
Re: Pictures of my rig with Omega Speakers
« Reply #380 on: 13 Jun 2025, 02:19 am »
Just got the Super Alnico High Output XRS.  Louis made them with integrated 8" downfiring subs.  We did some other upgrades, including internal wiring with ZenWave SL 17G. Dave also made jumpers for the subwoofers with his bass cables.  So far it sounds great, but I know there will be some changes during break in.
System:
Roon Nucleus
M4 Max Mac Studio running HQPlayer
Holo Red running as NAA
T+A DAC 200
Alan Eaton 45 SET Monoblocks
Zenwave D4 Interconnects
Zenwave SL 17G Speaker Cable
Intona Ultima USB
Kray
« Reply #381 on: 13 Jun 2025, 02:20 pm »
System:
Roon Nucleus
T+A DAC 200
Intona Ultima USB
Great setup! any more pics of the speakers? with no grills, etc? back on speaker? I'd definitely consider something like that.  :beer:
pstrisik
  • Holding pattern in Audio Nirvana in the PNW!
« Reply #382 on: 13 Jun 2025, 02:35 pm »
Very nice!  What are the other components?  The amp/pre remind me of the simplicity of Dennis Had's later work.  I currently have his earlier Cary SLP-98 pre but have had Inspire preamp and amp.
Also like that you have casters on the speakers.  I recently made platforms on casters for my 80+lb version of the SAM-HO.  Preserves the vibration control of the GAIAs while allowing for mobility.  I'll post a pic later today.
saxguy
« Reply #383 on: 13 Jun 2025, 09:53 pm »
The red ones are the 45 monoblocks made by Alan Eaton.  They're really good, but I've found that if I run my DAC at line level and use the volume control on the amplifier it will overdrive the amps, so now I just run the amps at full volume and use the volume control on the DAC.  It has an analog resistor based stepped volume control, so I'm not really losing anything by using it.  I'm waiting for a Decware Sarah 300B amplifier.  I love the sound of the 45, but I do feel the need to push the speakers a little harder at times and the 45 is limited in that capacity.
The DAC is the T+A DAC 200.  I'm running DSD1024 from HQPLayer into it.  Sounds phenomenal.
I don't have casters, though.  Those are just the Gaia III footers.
saxguy
« Reply #384 on: 13 Jun 2025, 10:08 pm »
uncola
« Reply #385 on: 13 Jun 2025, 11:12 pm »
wow they look great.  I love that louis is continuing to do such interesting custom designs.  the 8" downfiring built in subs are very cool, I'd definitely get those if I was getting the high output towers
pstrisik
« Reply #386 on: 14 Jun 2025, 12:43 pm »
My mistake, I can see the GAIAs now.
Here's a photo of my rig.  Old timers here are probably familiar by now.  SAM-HO with Rythmik 8" powered mid-woofers below.  Louis generously built both cabinets together and matched the grain.  The monitors are on OREAs with that black frame hiding them.  The top is stone slab.  Above that is a supertweeter with vintage Yamaha beryllium drivers and ~13khz high pass facing upward that I built.  GAIA footers.  The whole think on a platform with rollers underneath.
Currently with Auralic VEGA G2.2 streamer/DAC => Cary SLP-98 preamp => 1970's Pioneer M-22 - 30wpc all Class A.
This system is the best I've managed yet.  Still, I have on pre-order a pair of Orchard Audio Starkrimson monoblocs with LPS that will ship in the fall.  As wonderful as the Pioneer is and really good match for the Omega's, it is big, hot, and heavy (50lbs).  I'm getting too old to lift it!  The Orchard monos will be 50lbs together, but at least they are movable at 25lbs each.  :)  These are GanFET class D and 250wpc at 8ohms.  The reviews of GanFET technology in general have been very positive and the Orchards are getting universal raves, so I'm hoping for the best in terms of match with the Omegas.  I'll either return them or keep them and sell the Pioneer.
« Last Edit: 14 Jun 2025, 03:50 pm by pstrisik »
Kray
« Reply #387 on: 28 Jun 2025, 04:29 pm »
I think you’ll love the Orchards. I had Atmasphere Class D monos (GaNFET) with SAM’s and they worked beautifully.
Building a pair of Super Alnico XRS HO with built in subs is very tempting.
uncola
« Reply #388 on: 28 Jun 2025, 09:00 pm »
wow nice vibration control!  I have a pair of virtualhifi vibron footers on the way to try under my bookshelf speakers.  I've had orchard class d amps in the past and think you'll be very happy with them, especially the ultra premium version with the linear power supplies inside.
pstrisik
« Reply #389 on: 29 Jun 2025, 11:43 am »
Thanks guys.  Very much looking forward to the Orchards.  Long wait though.  Shipping in Oct/Nov!
alancb777
« Reply #390 on: 1 Sep 2025, 09:12 am »
I purchased my Omega Super Alnico High Output XRS speakers and the DeepHemp 8 Sub in Karelian Birch burl; purchased without hearing them first on September 5, 2024. It took a while to arrive, but the wait was so worth it!
Currently using the speakers ported with the sub disconnected due to the small room size and the bass from the speakers already sounds naturally good to my ears; will eventually add a second matching sub to fine-tune the overall sound.
I paired the speakers with my Linear Tube Audio Aero DAC, PS Audio Trio P-200 preamp, and the Alan Eaton 2A3 SET tube monoblocks, and they make the Omegas sing beautifully with great synergy. The amps' volume is set to 100% and overall controlled by my preamp. When playing music with HQPlayer, I tend to use PCM dithering and the bit settings at 18-bit for the AD1865 multi-bit R2R chip, no-oversampling with no digital filtering, and gain settings to either at -3dB or 0dB.
These Omegas are phenomenal speakers! Especially the way they project and image sound. They are the most musically engaging and one of the most transparent speakers I have ever owned. The sound tends to have an emotional factor. Every audio gear change, including preamp and speaker wire, is audible. Pair them with great audio gear and software and it will reward you with a massive soundstage with a surreal mid-range and depth. The thing about these Omegas is that it really brings you INTO the music, like if you are at front or in the stage with the musicians. The music sounds beautifully natural and coherent, and the sound can be felt as well. With the right configuration, they can sound lifelike.
Now, the best sound I have ever heard from the Omegas was when I implemented GentooPlayer and especially the Diretta streaming protocol on a regular Raspberry Pi 5 streamer and a Toshiba laptop as a server without changing the audio system's cabling, and stock tubes of my amps and DAC.
Using HQPlayer with Diretta alone may improve or change the sound profile by lowering noise levels vs HQPlayer's NAA protocol. Your mileage may vary.
When using Diretta MemoryPlay instead of HQPlayer, the Omegas started to sound so lifelike, it was like getting a DAC and amp upgrade along with removing a veil from the music. I will eventually compare its sound quality vs a high quality CD transport.
When using Roon, pairing it with HQPlayer along with the Diretta protocol will further improve Roon's sound quality vs NAA alone.
The purpose of the Diretta protocol software is to send a cleaner digital audio signal to the DAC. It is like getting a high quality linear power supply upgrade for your audio system. It is not a joke; it is a game-changer within my system.
My audio system looks like this:
Power: Panamax M5400-PM Voltage Regulator/Conditioner (Bought new)
DAC: Linear Tube Audio Aero w/stock tubes (AD1865 Multibit R2R chip/ZOTL/Class A) (Bought new)
Preamp: PS Audio Trio P-200 unbalanced (Obtained used)
Amplification: Alan Eaton 2A3 Pure Class A SET tube monoblocks (Bought direct)
Speakers: Omega Super Alnico High Output XRS (Bought new)
The streamer, server, and software:
Streamer: CanaKit Raspberry Pi 5 Starter MAX Kit
Server: Toshiba laptop
Server OS: GentooPlayer w/kernel extensions and Diretta Host
Streamer OS: GentooPlayer w/kernel extensions and Diretta Target
Server Music Player: HQPlayer w/Qobuz or Diretta MemoryPlay Controller
Digital audio chain:
HQPlayer w/Qobuz or USB flash drive → Toshiba laptop w/Diretta Host → Blue Jeans Cable Cat6A cable → Panamax Power Regulator/Conditioner → Blue Jeans Cable Cat6A cable → D-Link DGS-108 switch → Blue Jeans Cable Cat6A cable → Raspberry Pi 5 Diretta Target → affordable Phillips USB 2.0 spec USB cable → LTA Aero DAC
The speaker cables and interconnects:
LTA Aero DAC → SKW Audiophile RCA → PS Audio Trio P-200 preamp → Mogami 2549 w/Amphenol RCA → Alan Eaton 2A3 tube monoblocks → cheap Mygatti 16 AWG Tinned OFC copper cables w/banana plugs at amps → Omega speakers
After hearing different hifi rooms at audio shows, including AXPONA, I am currently having a hard time going back to a conventional multi-driver speaker with a passive crossover. My previous major speakers were the PSB Synchrony One towers. The speakers I would still consider are from PureAudioProject, Magnepan, Qualio Audio IQ Ultra, Cube Audio, Philharmonic Audio, Ø Audio, and Totem, but the Omegas have such a musical and coherent sound that it makes a lot of multi-way conventional speakers sound a bit artificial with its sound presentation. I no longer crave getting new speakers and will eventually upgrade my preamp, streamer, and all my cables.
The room does lack acoustic treatment, although the floor is all carpet.
All equipment, including the speakers are on its respective stock feet. I will upgrade the feet of both speakers in the future.
All power cables being currently used in my system are either stock and cheap aftermarket, and the RCA interconnects and the tinned speaker wire are all OFC copper that costed me a total of less than $130.
The lamp, D-Link switch, and all audio equipment are connected to the power conditioner except the Toshiba laptop.
Thank you Louis for creating an end game set of speakers. It may not be end game to others, but after checking out lots of high-end systems, the Omegas tend to have a wonderful balance of high fidelity, transparency, timbre, and musicality. I look forward to enjoying all my music through my Omega speakers for many years to come. :)
Opinion: If you have the Holo Audio Red streamer, I'd recommend that one day you try GentooPlayer OS or any OS with Diretta. With just a regular Raspberry Pi 5 running Diretta Target within my system, it improved instrument separation, clarity, 3-dimensionality, potentially lifelike treble with some of that sparkle and a more lively sound. My mom got to hear one of her favorite songs with my Omegas, and said that it sounded like if it was live.
Disclaimer: I do not work for Diretta. Diretta is audio streaming protocol technology from Japan.
Optional:
8K/4K video sample recorded with my phone. Please use headphones or good speakers to hear the music and the room:
https://youtu.be/B7UKsRIK9Tc?si=cGQSlY3DlOZjt220
« Reply #391 on: 1 Sep 2025, 09:31 am »
Congratulations, nice system.
