IDA-8 ($995) features and spec
mresseguie
Re: IDA-8 ($995) features and spec
« Reply #640 on: 12 Mar 2022, 09:59 pm »
Call John Casler. He's very accessible and always helpful.
https://nuprimeaudio.com/support/?v=7516fd43adaa
 :thumb:
Johlke
« Reply #641 on: 13 Mar 2022, 05:53 pm »
Thank you very much!  I will do that right away.
John Casler
« Reply #642 on: 13 Mar 2022, 06:28 pm »
The remote control on my IDA-8 has quit working.  Does anyone know how I can get a replacement?  I was able to speak to the guy who distributes Nuprime products and he asked me to email him and he'd get back to me but he never did.  I'd be open to buying a used remote or even a universal remote if those options are available.  Thanks!
I would suggest you fill out a "support ticket" and ask the procedure to get a new remote, or the remote codes so you can program an after market unit.
rustydoglim
« Reply #643 on: 14 Mar 2022, 11:14 pm »
The remote key codes are published on the product page: https://nuprimeaudio.com/product/ida-8/
Johlke
« Reply #644 on: 15 Mar 2022, 08:12 pm »
 Thanks for that info!
I've spoken with John Casler, who couldn't have been more helpful.  He guided me to complete a service request directly with NuPrime and so hopefully I'll have a working remote soon.  Thanks again to everyone for their help!
monster7
« Reply #645 on: 22 Dec 2022, 06:57 pm »
I would like to ask if I want to connect IDA8 to a headphone amp, I just use a pair of RCA to line out, set max volume, and let the headphone amp for volume control? But do I need to unplug the speaker binding post firstly? Thanks.
rustydoglim
« Reply #646 on: 22 Dec 2022, 08:26 pm »
IDA-8 wasn't designed to turn off the speaker output if the line out is connected to the headphone amp.
Unfortunately, you have to unplug the speaker cables.
Jeff_From_Michigan
« Reply #647 on: 23 Dec 2022, 01:02 pm »
I don't want to hijack the thread, but I wanted to chime in about the IDA-8 that I've had running since right when it came out - via USB from the computer then off to the Axiom Audio M3's in my desktop set-up.
This is such a beautiful sounding (and off-the charts value) amp that I will do whatever it takes to keep her in the system.  It is great to also know that the service, if ever needed, is first-rate!
Warnomore
« Reply #648 on: 18 Feb 2025, 04:34 pm »
Is the IDA-8 Roon-compatible? Has anyone tried?
Thx!
rustydoglim
« Reply #649 on: 20 Feb 2025, 10:15 pm »
For standard DAC, it doesn't need to be "Roon compatible", because as long as your Roon server can output USB audio (typical), or other digital outputs, IDA-8 or any DACs can decode it.
