0 Members and 1 Guest are viewing this topic. Read 9255 times.
I have listened for several hours to the Temple Audio Bantam Gold 25 wpc using a MOSFET Analog devises chipset.very respectable sounding, that being said I am waiting on their Bantam 1 which is a true Dual Monoblock In a full size case 3 times the power supply capacitance about $800 U.S , and a SE model much better regulated linear power supply Clarity MR coupling capacitors and Nichicon Gold power caps A conservative 40 WPC fancy wooden front panel. The SE is roughly $400 more.These prices would be at least double if bought in a store . All designed and built in the U.K.I will forwards my findings after I receive my amp .
I'd go with the newer TI chip over the Crown.The Omegas don't need a lot of power, and the TPA3110 or 3116 should drive them quite well for not much money.I like the Crown, but in my use it is a much better subwoofer amp than full range amp.
Thanks, I appreciate your candor. I quite like the TPA3116 (with an Astron) as an amp - that regardless of price - is very musical. I'd rather not suffer unnecessary disappointment, wasting my time and money with a more powerful, but less musical amp.
The Crown excels as a subwoofer amplifier and it's built in crossover tells me that's what it was designed for.
The TPA3116 is very inexpensive. But then you buy the red board, then the black board, then the green board, then the black and red board and probably a violet and pink board too. Meanwhile you have a pile of 'veils' to deal with that were 'lifted' each time you bought a new board. Then you buy the cheap power supply. Then you buy an expensive power supply. A few more veils added to the pile. Then you realize that piece of board with wires snarling all around it needs a facelift. Then you put it in a cigar box. Then you mod an old toaster case. Then you buy the expensive milled metal block case.There went C n C. The Bantam Gold sounds interesting.
C&C class D for the Omegas would be a $20 TPA3116 paired with a $35 Astron linear.
I'd go with the TDA7297 over a TPA3116, but it isn't a class D. It needs a few changes at the least.
