bad sound ,,,,,
0 Members and 1 Guest are viewing this topic. Read 1237 times.
2bigears
bad sound ,,,,,
« on: 15 May 2015, 10:51 pm »
 :D   hi all ,,,, well my TT has a new deal going on ?? it sounds worse than my digital.   ha
           would it be the pre tubes for the line stage ??  or the cart ?? nothing is forever i new !!!!   dam ??
               not sure which to do 1st ????   missing my spinner !!!! :D
ElliottStudio
  • I do it because I love to.
    • Elliott Studio Arts
Re: bad sound ,,,,,
« Reply #1 on: 16 May 2015, 01:23 am »
Could be a number of things -
Dirty stylus
improper setup (VTF, VTA, azimuth, zenith, etc..)
dirty contacts on the cart lead clips or input jacks to preamp
I would starts there..
steve f
Re: bad sound ,,,,,
« Reply #2 on: 16 May 2015, 01:35 am »
Help us out. Describe your phono system please.
2bigears
Re: bad sound ,,,,,
« Reply #3 on: 16 May 2015, 02:24 am »
 :D  THANK YOU ,,,, its a Rega9,, xx-2 Cart ,,,, VAC REN PRE ,, i play very clean records always of course ..
           can't say the milage on the tubes ?? but i'm not happy .. can't play my black discs ....ha  :D
neobop
  • BIRD LIVES
Re: bad sound ,,,,,
« Reply #4 on: 16 May 2015, 07:28 pm »
Still not much to go on, can you describe how the sound worsened?   Sounds fuzzy, bass or treble lacking, pitch ?
How old or how many hours on the cart?  Have another to substitute?
You'll have to be more forthcoming with information.  Most likely candidates in order of likelihood - dirty stylus, damaged/worn stylus, old belt needs replacing, tubes.
Did you check the contacts as suggested?  One loose wire could make it sound like drech while basic functions still work.
neo
