Lampizator B7 no output
Mike Long
« on: 9 May 2015, 06:13 pm »
Hi guys,
I just picked up a B7 used, serial no. 659, and I cannot get output via the coax input, tried 2 sources, or the analog input.  Any suggestion?  Also, do you know how I can get the warranty transferred to me?
Mike
findog3103
Re: Lampizator B7 no output
« Reply #1 on: 9 May 2015, 07:01 pm »
One time I couldn't get sound out of my L4 and it was just that the rectifier tube went. I swapped it and all was fine.
Berto
« Reply #2 on: 9 May 2015, 07:52 pm »
Hi Mike, sent you a PM to help you!
Mike Long
« Reply #3 on: 10 May 2015, 03:47 pm »
Berto,
I did not get your PM.  My email is [email protected].
Mike
Berto
« Reply #4 on: 10 May 2015, 10:36 pm »
Berto,
Mike
Email sent 15mins ago.
Mike Long
« Reply #5 on: 11 Jun 2015, 06:09 pm »
I appreciate everone's feedback. This turned out to be a system setup issue.
Thanks, Mike
