Von Schweikert VR4.5 isolation feet/module decoupling
vinylfreeze
Greetings,
After reading many satisfied customer reviews I am excited to try your products.
I have a set of VSA/VR4.5 speakers which are presently sitting on DIY isolation blocks.
It seems your VSA special for module decoupling is the perfect option?
What is your recommendation for speaker/floor isolation?
At present speakers are located on a concrete/tile basement floor(not opposed to adding carpet
under speakers if recommended,have large thick wool carpet section in front of speakers(center of room).
Speakers are 150lbs total(97bass/53mid-hi).
Thanks for your input.
Matthew
Herbie
    • Herbie's Audio Lab
Re: Von Schweikert VR4.5 isolation feet/module decoupling
« Reply #1 on: 9 May 2015, 08:22 pm »
The Von Schweikert Special is perfect for decoupling the VR4 modules. Isolating/decoupling the speaker/floor interface is also beneficial. Either a Giant Cone/Spike Decoupling Glider under each of the stock spikes or four Giant Fat Gliders under each bottom cabinet in place of spikes altogether is ideal.
Steve Herbelin
Herbie's Audio Lab
vinylfreeze
« Reply #2 on: 9 May 2015, 09:12 pm »
Thank you for the prompt reply.
I just ordered the VSA special & 8 giant fat gliders(as I do not have spikes).
I look forward to hearing my system with these products and will post my listening impression.
Matthew
