0 Members and 1 Guest are viewing this topic. Read 10270 times.
No, BFA are brass tubes... they are cheap and convenient but not the best sound quality. Copper is too soft to use like BFA so they must lock, which also makes them more complicated and expensive.
Not necessarily true, we have some BFA's made which are 98.6% copper and 1.4% Beryllium. The Be makes them plenty strong to retain shape without all the impurities of Brass.
I use ZenWave/Dave's speaker cables with bare terminations. I read a paper that was published by the Boston Audio Society that made me re-think loudspeaker terminations and have use bare terminals ever since. I do however live in a desert climate with little humidity and a fairly stable temps year around.If I ever had Louis build me another pair of speakers I would like to use ZenWave cables from the drivers, exit the cabinet and run all the way to the amplifier without any stop gaps in between. The main issue with that though is ... if I ever move I wil be limited to placement, but I still think this would give the best performance possible so it would be worth the risk to me.
The only bananas I use are pure copper with locking mechanisms, they are more expensive but don't negatively affect the sound. Pure copper spades tend to be less expensive and perform about the same. Bare wire sounds about the same as a cable with high quality connectors but it is less convenient and there are usually issues with corrosion so the sound will get worse over time unless you keep the contact area clean.
Are BFA bananas considered "quality" connectors? I'm not up on all the techno speak -- just a simple man who trusts his ears. But purely from an ease of use perspective, they are my favorite connectors.
Zenwave cables (DaveC113) makes a very good cable that is voiced with Omega speakers. A no brainer IMO.
Two other options to consider if you control the interface on the back of the speaker and the terminations of the interfacing wires:Neutrik SpeakNsElectra Cable Tube ConnectorI'm in the middle of rigging my active 2-way system and had every intention of doing what beowulf describes (pass-thru in back of speaker direct to spring-slips on drivers), but I'm finding that there are practical limitations making me reconsider it in favor of one of the above two options.
...for RC planes (another hobby of mine)...
