Can you recommend a tube amp that's reasonably priced?
0 Members and 1 Guest are viewing this topic. Read 7451 times.
eclein
Re: Can you recommend a tube amp that's reasonably priced?
« Reply #20 on: 4 May 2015, 07:02 pm »
I wish I still had my Musical Paradise amp for phones...loved it for either actually.....Great amps.
The EF5 of the MusPar are the 2 I'd say but I've never heard the little dot......
JimJ
  • Ut Prosim
« Reply #21 on: 7 May 2015, 06:19 pm »
If you're going to be in it for the long haul stretch your budget and hunt around for a used Woo Audio offering.
They're built like tanks here in the US and you won't get the upgrade bug for a better amp.
I'm looking at getting back into hi-fi (my SET setup is still in storage :( ) and the Woo WA6 almost looks too good to be true. Really thinking about pairing one with a set of closed cans in the $300 range and a Schiit Modi DAC...
Upsguys88
« Reply #22 on: 10 May 2015, 07:35 pm »
I really enjoy the hybrid Schiit Vali amp and even better with the modi as a dac/amp combo!
milford3
« Reply #23 on: 10 May 2015, 07:56 pm »
Here you go.  Can't go wrong with the Schiit.
http://schiit.com/products/valhalla-2
SteveFord
« Reply #24 on: 10 May 2015, 08:09 pm »
The WA6 is quite good.  The only downside is it takes quite a while to warm up as it's quite the chunk of metal.
I sold mine to help finance a guitar but I'll get another one sooner or later.
