S/PDIF output on Ripper not working
nimrod
« on: 28 Apr 2015, 11:55 pm »
I was clawing through a drawer and came across the Ripper that I built many moons ago. Just for fun I hooked the S/PDIF output
to my DAC, but got no sound from my DAC. Solder joints are good. All the correct parts are populated. Any suggestions? Thanks.
fredgarvin
Re: S/PDIF output on Ripper not working
« Reply #1 on: 1 May 2015, 01:44 am »
Tap on it with a plastic spoon.  :green:
hagtech
« Reply #2 on: 3 May 2015, 09:57 pm »
Are you feeding it a USB signal?  The SPDIF output (which was optional) comes only from the USB decoder chip.
jh
nimrod
« Reply #3 on: 5 May 2015, 02:32 am »
Darn, I knew I shouldn't have thrown away that plastic spoon.  :icon_lol:
Thanks, Jim for the info. I thought that the S/PDIF out was functional with the phono input.  :duh:
hagtech
« Reply #4 on: 5 May 2015, 05:30 am »
It might be if you select "digital" mode on the front switch.  I forget how that chip works...
jh
