0 Members and 1 Guest are viewing this topic. Read 4616 times.
Bought a quad about 16 months ago, though the 'sound' showed promise I had 'problems' with a couple of the tubes keeping bias... But a couple months ago tried their 'new' 5751, and really liked it, might just be my new fav. 12AX7 type new issue tube.
Did you have issue with them holding bias right away ? Or was it something that crept in after some time ?
Curious if you have had a chance to break in the KT 77's and your impressions?Thanks -
If your amp has loose sockets , I'd shy away from the JJ 's(the 77's anyway).
