Need Acoustat 1+1 manual - need to disassemble for move
0 Members and 1 Guest are viewing this topic. Read 1366 times.
bedo
Hi,
Can anyone point me to instructions on what to do to prep them for moving?
Thank you!
Jeff
Re: Need Acoustat 1+1 manual - need to disassemble for move
« Reply #1 on: 19 Apr 2015, 03:41 pm »
You need to register to download it:
http://www.hifi-manuals.com/Acoustat/1-plus-1/downloads
bedo
« Reply #2 on: 19 Apr 2015, 03:50 pm »
Thank you!!!
Any chance someone can advise what size allen wrench for these screws?!  None of mine around the house fit and my eyes aren't what they used to be... :icon_lol:
The manual says to use the allen wrench supplied but does not mention size used as far as I can tell.
Thank you again!
Phil A
« Reply #3 on: 19 Apr 2015, 04:40 pm »
Thank you!!!
Thank you again!
If you can't find out, it is cheap enough to buy something like - http://www.harborfreight.com/36-pc-sae-metric-long-reach-hex-key-set-62171.html
bedo
« Reply #4 on: 19 Apr 2015, 05:24 pm »
Thanks, I have a metric set.    Off to home depot.
Thanks guys!
