USB cable
0 Members and 1 Guest are viewing this topic. Read 3830 times.
dusk_
USB cable
« on: 16 Apr 2015, 05:00 pm »
Is there a USB cable included or should I grab one?
What are the connector end sizes/types?
What do people recommend for USB cables.
I know I don't have to spend a lot, just curious about some cool looking ones.
Will pexon cables be suitable?
http://pexonpcs.co.uk/collections/usb-cables/products/usb-cables
ebag4
Re: USB cable
« Reply #1 on: 16 Apr 2015, 05:17 pm »
It may be more information than you want, however you might find this thread interesting:
http://www.audiocircle.com/index.php?topic=133819.0
Best,
Ed
Vinnie R.
Re: USB cable
« Reply #2 on: 16 Apr 2015, 05:45 pm »
I've tested the LIO dac with this:
http://www.monoprice.com/Product?c_id=103&cp_id=10303&cs_id=1030301&p_id=5438&seq=1&format=2
It has been 100% reliable, sounds great - you can't go wrong for $1.34 + shipping.
If you are going to pay much more than that, try to get a return policy and you decide if the more expensive cable is
worth the cost to you.
NOTE: I am not saying that "there is no difference with USB cables" - I'm just pointing out that the cable linked
to above works very well with the LIO dac.  :wink:
AND - whatever cable you try, make sure it is at least USB 2.0 rated.
Vinnie
rollo
  • Rollo Audio Consulting -
Re: USB cable
« Reply #3 on: 16 Apr 2015, 07:32 pm »
Vinnie
   For a $1.34 retail you might consider including one with a DAC purchase.  :P
charles
Vinnie R.
Re: USB cable
« Reply #4 on: 16 Apr 2015, 07:35 pm »
charles
I knew that one was coming  :green:
srb
Re: USB cable
« Reply #5 on: 16 Apr 2015, 07:49 pm »
The good news is that in quantities of 100, they're only $1.11.
Just for fun I covered that same cable with Techflex Flexo F6 split-loom and heatshrink, and an audiophile acquaintance said the music came from a blacker background and had a much wider soundstage than his AudioQuest Carbon.  ;)
rollo
Re: USB cable
« Reply #6 on: 16 Apr 2015, 07:54 pm »
   Sorry Vinnie could not resist, I owe ya some pasta and my famous marinara/shrimp.
charles
olegausany
Re: USB cable
« Reply #7 on: 16 Apr 2015, 10:30 pm »
I'm well  aware that most users don't believe that cables make noticeable difference but for those do or trust only their own ears I would recommend to contact The Cable Co and get a home trial of several cables and find out for yourself the way I did a good while ago to find out that from 5 cables I have tried that Audioquest Carbon works best for me.  I don't work for the Cable Co so this is not advertisement but just my personal opinion
dusk_
Re: USB cable
« Reply #8 on: 17 Apr 2015, 12:59 am »
I went with a custom cable from pexton, as well as the monoprice cable, just to see if there is a difference.
The pexton process wasn't the best to see all the options, so I'll report back once I get it, and had a chance to A/B the two.
I *THINK* it's going to look something like this.
They make some really pretty cables.. audio cables, too!
http://pexon.imgur.com/all/
Vinnie R.
Re: USB cable
« Reply #9 on: 17 Apr 2015, 04:25 pm »
Hi olegausany,
Welcome to the VR forum!
I agree - and until you try and listen for yourself, you will not know.   :)
Quote from: dusk_
I like that color!  :thumb:
Quote from: rollo
Hi Charles,
Sounds tasty!  :drool:
Vinnie
