SOLD: Sony TTS-3000a Servo-Controlled Belt-Drive Turntable JUST SERVICED
0 Members and 1 Guest are viewing this topic. Read 1022 times.
danvprod
SOLD $600 shipped and palpal'd CONUS.
Selling my Sony TTS-3000a turntable and custom plinth.
*includes:*
Sony TTS-3000a transcription turntable.
Custom wood and stacked plywood plinth.
Pre-drilled, removable armboard.
Audioquest sorbotrane mat.
New belt.
*Turntable has been recently serviced and speeds have been checked to be accurate at both 33 and 45 RPM settings.
*Service covered:
Replacement of several resistors that control motor speed.
Tightening of motor mount.
Replacement of belt.
Checking that all functions are properly working.
Oil Spindle.
This is a vintage used turntable, however it's pretty clean and in good shape for it's age. Some things to note about condition:
Plinth has been drilled for both a SME arm and the Sony tonearm. I have a SME arm board that I can include if the buyer is interested.
There are several scratches on the plinth.
Platter spins free and smooth, bearing is in good condition.
Since this is a servo turntable, you will often have to plug it in, then set the speed with the speed pot. It's easy to do and always very close.
I have small rubber feet on the plinth, but it is still a bit wobbly and may require different rubber feet to balance on your piece of furniture.
This was taken out of my personal playback system (I have upgraded turntables.)
« Last Edit: 15 May 2018, 12:55 am by danvprod »
