0 Members and 1 Guest are viewing this topic. Read 33743 times.
Check out audiostream.com for reviews of desktop oriented playback gear including speakers. It's a spin off of Stereophile magazine. Speaker reviews are mostly of active 2-way speakers, similar to what is used in the studio to record/mix the music we listen to. I own large single driver speakers, but recognize that the studio folks are the serious listeners (working to find all the flaws and create the best possible recording) while we just listen to be entertained. It continues to amaze me the differences between the two camps. They don't understand how we can be so fixated on tweaks yet tolerate tons of coloration. OTOH we can't understand why they have never "grown" beyond generic cabling/amps, yet we base it all on their means and methods for recording.Oh, and Flinx99, highly recommend using whatever "natural" recordings you're familiar with to evaluate gear with. Natural recordings (live music created without electronics) provide the only gold standard to measure against (everything else is a yours versus mine, in terms of gear/venue).
Not trying to be a musical elitist, just saying that listening to hard rock for instance, can only boil down to an exercise of comparing listening to one huge set of sound reinforcement gear in an arena versus your gear in your room.
Being in an Omega Circle, I'd imagine you would see more positive impressions of Omegas. That said, is it at all possible for you to listen to both speakers? Those LS50s are really special, as the many raves and awards would indicate. Though they will not shine if underpowered. And yes, I would imagine that they may not be as compelling at low volumes. But their bass and ability to fill a small room is excellent. An exceptional speaker, but one that will sound different than the single-driver sound. For better, for worse. Very often a matter of trade-offs and personal preferences about what tradeoffs are worthwhile and which are not.
Hi roscoeiii,If you read further up the thread, you will see there are those who have heard both the KEF and Omega.
Intersting, Flinx. We also share similar taste in music. I listen to a good bit of chill/ambient particularly in the mornings while I work. French Band Air is great. Thievery Corporation is also a favorite. It's good music. Nothing to feel guilty about. This hobby is supposed to be inclusive. Everyone enjoys music, afterall. In the afternoon I typically switch to something more energetic. I listen to pretty much everything except pop country. I'm also not a big fan of big band jazz. All those trumpets eventually drive me nuts. Depending on music type and loudness, you just have to temper your expectations with regard to bass extension / output. Do you plan to get a sub? I won't say it is a requirement, but it is a welcome addition.
I love Thievery Corporation. The Cosmic Game is my favorite of theirs. Have you listened to the band Zero 7? I have what I think is a good sub---a Rel T-9. I use the high level connection and crossover just below the bookshelf bass capabilities. I think there is a good chance that this sub would work well with the Omegas.
Everything you say is true. Even $100k speakers have tradeoffs. The LS50's are exceptional speakers. As you pointed out (as did I), they just aren't compelling at low volumes. As the OP is looking at near field use (possibly desktop use), I can't imagine the KEFs working well (low volumes - likely less than 1 watt) without equalization. Omegas, from my experience, are FAR more flexible with regard to low volume levels and sounding more balanced. I'm sure there are many reasons for this, including their much higher sensitivity, lower moving mass, and having no crossover. I wouldn't say someone else is "wrong" for liking LS50's over Omegas. Not only do personal preferences come into play, the listening environment as well as desired typical listening levels will dictate a lot about what speaker will work best in any given situation.....and that's why both Omega and KEF provide several options to choose from.
All you can do is try. The key with running a sub with Omegas is that the sub has to be very fast.
Way back in the late seventies, I was in dealers show room who illustrated something I will never forget. He played two different speakers by the same manufacturer; one pair fairly efficient rated 92db about half the price of the another pair, which were rated fairly inefficient at 85db. He adjusted the volume to compensate for the difference in sensitivity so each produced the same sound pressure level. At 65 db weighted, the more efficient speakers sounded much fuller and alive than the less efficient speakers. However, when the gain was increased by 20 db, those same speakers sounded thin and void compared to the less efficient counter parts. On that basis, I bet the Kef's will most likely sound fuller and tonally richer than the Omega's at higher spl's.
Though that said, I have had good luck with RELs in a high efficiency set-up.
