0 Members and 1 Guest are viewing this topic. Read 12997 times.
You'd probably have to wait for a pair to show up on audiogon.
Typically the Sound Dynamic speakers show up on Audiogon from time to time. If you are planning on using these monitors for a computer though, they are waaaay overkill since they were not really meant for any sort of computer use or near field listening. I also suspect that they won't reveal their "midrange magic" from less than high end electronics. They are not sheilded either. These speakers will most likely sound the best in high end set-ups, where you are sitting away from them and they are awa ...
Those BR1's are only 85 db efficient. I heard those speakers and liked them very much. Don't expect to blast it too loud as you'll clip the amp and burn up the tweeters. For $140 they are great.$200 for RAD Micros???http://www.rutledgeaudiodesign.com/speakers.htm
