FS - JOB225 Amp *SOLD*
0 Members and 1 Guest are viewing this topic. Read 2043 times.
rklein
  • My finest audio piece ever!!
« on: 1 Apr 2015, 02:43 pm »
FS - JOB225 - $1,250
125 watts per channel of beautiful power. I preferred this amp to my NCore Monos for presence, sound stage width and height.
I’ve owned it for a about one and a half years but have decided to replace the JOB with a Line Magnetic integrated.
If your speakers are even reasonably efficient (mine are 89db), this is a fantastic amp. I listen to classical, jazz and rock and it’s great on all music. No edginess at all…
I will include an Audio Magic SuperFuse ($105 value) with the JOB225. Unit is mint in every way.
6Moons gave it the Blue Moon award… see the review:  6moons.com/audioreviews/job/1.html   Everything Srajan says is true. And it gives the best bass I ever had in my rig.
Sound and Vision Brent Butterworth compared it to a $5000 Krell. See review:   soundandvision.com/content/review-job-225-stereo-amplifier?page=0%2C0
TECHNICAL DATA from Job Corporation site
POWER
Nominal Power: 125W on 8 Ohms per channel valid for the full range of AC voltage (incl 100V for Japan)
Power RMS (Goldmund FPP Standard): 200W on 8 Ohms each channel at nominal AC line voltage
FREQUENCY RESPONSE
These figures are valid for any level between 0 and nominal power.
+/- 0.5 dB, 10 Hz - .1 MHz.
+/- 3 dB, 2 Hz - 0.9 MHz.
INPUT SENSITIVITY
Nominal level : 0.75 V.
Unbalanced only (RCA)
51k input impedance.
GROUP DELAY LINEARITY
Propagation delay 60 V/m s.
Rise time : 100 dB.
POWER SUPPLY
Nominal line voltage : 115/230 V selectable covering 95V to 260V}
2 separated power supplies (left and right)
Maximum power consumption : 450 W.
SIZE AND WEIGHT
36cm (14.2") W x 24.5cm (9.6") D x 8.8cm (3.5") H. - Weight : 7kg (15.4 lbs) net.
Amp is located in NE Ohio.
Please add 3% for PP. Shipping should not be more than $25 via FedEx.
Thanks for looking,
Randy
« Last Edit: 6 Apr 2015, 04:43 pm by rklein »
rklein
Re: FS - JOB225 Amp
« Reply #1 on: 1 Apr 2015, 04:30 pm »
Will post pictures later tonight.
Randy
rklein
Re: FS - JOB225 Amp
« Reply #2 on: 2 Apr 2015, 12:50 am »
Pics  :thumb:
Randy
rklein
Re: FS - JOB225 Amp
« Reply #3 on: 4 Apr 2015, 08:49 pm »
I can put the stock fuse back in the JOB which would lower the price to $1,150.
Add 3% for PP unless using "Friends and Family"  Option
Shipping via FedEx will be set at $30.  If more, I will cover. If less, I will refund the difference.
Regards
Randy
rklein
Re: FS - JOB225 Amp
« Reply #4 on: 5 Apr 2015, 02:00 pm »
Sale Pending
rklein
Re: FS - JOB225 Amp *SOLD*
« Reply #5 on: 6 Apr 2015, 04:43 pm »
SOLD
