0 Members and 1 Guest are viewing this topic. Read 29096 times.
I do not believe you have hit the point of diminishing returns at the budget JLM has set. There is a massive difference in performance between, for example, the Teac and the Auralic, which does scale with price. But it would be hard to live with the Teac after you've heard the Auralic.
I was using a Mac Mini along with the Vega. I changed the Mac Mini to an Aries. Did the sound improve? Yes. Did the sound improve as much, when I replaced my previous DAC (a very tricked out Buffalo) to the Auralic Vega?No. Absolutely not. Under $10K, I would seriously look at the Vega. You can upgrade your MacBook later if need be. I know of nothing cheaper in cost than a Vega that is worlds better than it. Different? Maybe. Worlds better? Nope. But remember, it's supposed to be FUN!Best,Anand.
From the professional reviews, the only issue I've found with the Auralic Vega is it's digital volume control that reportedly is pretty crummy at lower levels (where I'd expect to be most of the time), making it useless for desktop use (or to allow me to sell my pre-amp).BTW, the stated budget (like any budget should be) is the targeted maximum. Lower priced solutions that come close would be a plus!
From the Auralic Vega website: Analog Outputs1*Balanced XLR(output impedance 4.7ohm)1*Single-ended RCA(output impedance 50ohm) I suspect most DACs with a correctly designed output stage will have a low enough output impedance that there will not be a problem with an impedance mis-match, whether it will sound good driving a load directly without an intervening preamp or buffer is a more complex question with an answer that starts with, it depends ....Scotty
JLM,If i was looking for a DAC with volume control, I would consider using Wyred4sound DAC 2. I have several systems and the DAC 2 works very well..V....
Did you try attenuating the output in the player software via its volume control?Scotty
