0 Members and 1 Guest are viewing this topic. Read 6503 times.
on the subject of OSs ,win 7 and above dont run 32bit win programs..so i keep my win xp machine for that task...
That will work as long as you don't connect to the internet.The Risk of Running Windows XP After Support Ends April 2014"There is a sense of urgency because after April 8, Windows XP Service Pack 3 (SP3) customers will no longer receive new security updates, non-security hotfixes, free or paid assisted support options or online technical content updates. This means that any new vulnerabilities discovered in Windows XP after its “end of life” will not be addressed by new security updates from Microsoft."Link: http://blogs.microsoft.com/cybertrust/2013/08/15/the-risk-of-running-windows-xp-after-support-ends-april-2014/Windows XP sees its first major vulnerability after Microsoft ends support"A division within the United States Department of Homeland Security has warned against using old versions of the Internet Explorer browser, following the discovery of a security flaw that can lead to “the complete compromise of an affected system.” The flaw has led the division to advise the use of alternative browsers until Microsoft fixes the problem."The flaw is the first major security problem found with the Windows XP operating system, which was released in 2001, since it was officially abandoned by Microsoft on April 8, 2014. The company warned Windows XP users that it would not be fixing any more problems with the software after that date — if they wish to keep their computers secure, users must use a different Web browser or upgrade their computers to a newer version of the operating system."Link: http://pando.com/2014/04/28/windows-xp-sees-its-first-major-vulnerability-after-microsoft-ends-support/Just Google "Windows XP vulnerabilities" for more info.Wayne
