New bases for Iso-balls
plastico
« on: 26 Mar 2015, 01:46 pm »
Hi Steve . I see that the bases for the Iso-balls have changed. What are the benefits and can I just change the bases with my current Iso-ball setup?
Doug
Herbie
    • Herbie's Audio Lab
Re: New bases for Iso-balls
« Reply #1 on: 26 Mar 2015, 03:03 pm »
Shouldn't be any need to change from your present set-up. The main benefit of the new base is that it creates a taller footer, beneficial for some turntables that have stuff under the plinth or chassis requiring a lot of footer height. Original and newer IsoBall bases both are superb; any subtle sonic differences between them might vary a little from one system to another according to system synergies and personal preference. Though you wouldn't find a substantial difference between them, it's just as likely you'd have a preference for the bases you already have.
Herbie's Audio Lab
plastico
« Reply #2 on: 26 Mar 2015, 07:35 pm »
Thank you Steve. :thumb:
Cheers, Doug
