0 Members and 1 Guest are viewing this topic. Read 37990 times.
Interesting... I was unaware of the energy contract through xcel. I'll have to look into that a bit more.
FWIW.We recently moved into a planned community and all of the houses have Solar Panels on a 20 year lease from Solar City. You have little/no choice in the matter (they decide on how many panels to put onto the roof during the construction period. This is based on the model of the home with factors like # of bedrooms and the average use for other similar models in the past). You can contact Solar City and talk to them about having more panels installed after you take possession of the house.We are still in the process of moving in, so we are not here full time, nor are all of our electric appliances running yet. We will get a spa at some point, which will change things. During a typical sunny day, our array produces between 30 and 35 kwh. It is a VERY moderate climate here. AC is not standard and would typically be used 10-15 days a year (as a guess). We do use natural gas for heating, hot water, and Range.Our first electricity bill was under $5. I liked that part.
That situation sounds like it falls somewhere between reasonable and enlightened. May turn out to be heavenly since it suggests a like minded neighborhood.Having to go to Solar City for modification after purchase doesn't seem too burdensome. In my area of Colorado we go through an application process that includes engineering plans and evaluation thereof if we want to join the grid. Once you are approved and installed and operational, any modification requires a repeat of the entire process, which really isn't as bad as I made it sound.Where is this place? I probably can't afford it but you never know.
Hey Phil - After my last post, I remembered you are in Florida, which is famous for discouraging solar installs. Did you have any difficulty with red tape or protectionist laws? It's funny how the private sector/free market guys are always busy trying to buy themselves a legislated monopoly.
If you go solar, couldn't you get a hybrid car and cut down on gasoline usage at the same time?
