A better power supply for Bugle 2
0 Members and 1 Guest are viewing this topic. Read 8815 times.
REY
« on: 8 Mar 2015, 04:18 pm »
What is everybody out there using? I was thinking batteries perhaps, and then I saw this on ebay
http://www.ebay.com/itm/251551198778?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I wonder how much better can the bugle 2 perform with a nicer power juicer
Thanks in advance guys
hagtech
Re: A better power supply for Bugle 2
« Reply #1 on: 9 Mar 2015, 03:19 am »
I am working on an updated supply.  It will help more with PICCOLO2 performance than BUGLE2, but any sort of improvement like this is good.  Hopefully they will be for sale this summer.
For now, you'll have to give this a try.  The output needs to be floating though - with neither output tied to EARTH.  The other option is to use a dual supply (+12V, -12V, GND) and remove U1.
jh
Elso
« Reply #2 on: 10 Mar 2015, 07:43 am »
I am using a PCB with two TPS7A4700 4.17uV ultralow noise regulators. It brings me in audio Nirvana with the Piccolo 2. Simply removed the inductors, supply splitter  and 470 ohm resistors. Connected a wire to the ground clamp for the zero Volt reference.
tlainhart
« Reply #3 on: 26 Mar 2015, 12:45 am »
Is this the sort of thing you're designing?
http://welbornelabs.com/cat/phonostagepowersupplyupgrades.htm
hagtech
« Reply #4 on: 28 Mar 2015, 03:19 am »
Similar, but smaller.  And important the negative side of output is not tied to ground.  The CORNET3 supply will be bigger.
jh
izerbi
« Reply #5 on: 30 Mar 2015, 10:10 am »
Can we not use the bugle PS? Mine worked flawlessly since day one and is out of use since i built the bugle2.
If it can be used, how to connect it?
Thanks for helping.
hagtech
« Reply #6 on: 3 Apr 2015, 05:44 am »
You could use the original Bugle Power Supply, but it would require modifications to the Bugle2 circuit (removing J1 and U1).
jh
