0 Members and 1 Guest are viewing this topic. Read 23544 times.
Here is how I see this whole system when done.Amplifiers: Odyssey Audio Kismet Extremes Monos in Stratos Case (Left, Right Channels), Kismet Extreme in Khartago Case (Center Channel), Kismet Extreme Stereo in Khartago Case (Rear Channels)Speakers: Perfect Storms (left and Right) Matching Perfect Storm Center Channel ( working out the details), Build another set of the top ends of the Perfect storms and put them on stands for the Surrounds, Get Vapor to design 2 Subs to complement the system.Preamp: Bryston SP-3Digital: Audio by E – Silenzio AE-S2.5 high performance media server, Synology DS415+ setup by Audio by ECables: ZenWave Audio all aroundPower Conditioner: SurgeX SEQ - ZenWave Audio EditionIsolation: Stillpoints under everythingI forgot, I have GIK coming down to give their 2 cents on the room. I am sure they will have some solutions.
So I am curious what Subwoofer setup would go best with this system.
If you need a sub at all, probably something top notch. Perhaps a Rel Gibraltar?
The bass from the Perfect Storm would, I'd wager, obliterate that from the Rel. The woofer in the PS is on a whole different level, the cabinet construction and design is another level. A JL Gotham or Velodyne DD 18 might give more impact, but sincerely doubt they'd have the tonal density or definition. All I can think of that would match the PS bass AND give more impact/scale would be something like a Precision Devices 21" or 24" in a HUGE transmission line cabinet and around 4000 watts.
Now that sounds like fun. Although it also sounds like the size of an end table.
Probably something on the order of 4' tall, 3' deep, and 2.5' wide ... that driver needs a lot of volume to deliver what they're capable of.
LOL you beat me to it. I needed to get a measuring tape.That is too big for my wife to accept.
Wouldn't you be better off with Ryan building two subs with the same 15" driver and powered by a class D amp?
I think one of the things I need to consider is that when I was building this system for my Von Schweikert speakers, the subs were to be run with signal sensing cables off the bass cabinets of the left and right speakers. This design would be used pretty much all the time, music or movies, and to make them like an invisible integration with the speakers neutralizing room nodes. With the Perfect Storms this is not really necessary. The subs would be more for watching movies. I am very confused right now on the best way to proceed.
Why would you not have room modes with the new speakers? Seems to me that a distributed array of some sort would be desirable. Looking forward to seeing the new design, btw.
I am sure I will have room nodes. However, what I don't know is if the little VS Shockwave V-10 subs are the answer. I am sure with the VS speakers they would be awesome, but I want a much higher level of performance than the little VR4jr's are capable of delivering.So what I don't know is, what nodes I will have, what solution is best for them then with the much bigger and higher quality of the Perfect Storms, and how best to determine this.I think Ryan is probably right, but I just like to try to understand the end result. I just spent a lot of money going down one road, and have now gone a total different direction. It is ok, as I have other uses for the VS setup, but I prefer to have a solution in mind.
