Bryston 4BST Static
0 Members and 1 Guest are viewing this topic. Read 852 times.
maclark7029
Bryston 4BST Static
« on: 27 Feb 2015, 02:02 am »
Hi,
I recently purchased a used 4BST that sounds great except for when I turn it off after listening for a while.  As it is powering down, I hear a fairly loud static from the right speaker that lasts about a second.  Is something failing?
Mike
cooperman1955
Re: Bryston 4BST Static
« Reply #1 on: 2 Mar 2015, 05:06 pm »
You are hearing the death throws of the front-end of the amp, they should be muted.
The yellow NAiS mute relays can get stuck with age.
Bryston will replace them under warranty with black OMRON relays.
