0 Members and 1 Guest are viewing this topic. Read 14092 times.
Recently, after moving some gear around and rerunning cables, like a bone head, I put my ICs in running backwards. It screwed with the sound for sure! So check that as well Tom.Good luck and I hope you can get things singing soon.
I actually find the Ulysses to be have a bit too much in the highs. It's hard to describe - they are not 'bright' in the conventional sense, but they have a lot of treble energy, if that makes sense. IMO, the Athena is the superstar of the Daedalus lineup - perfectly balanced from top to bottom and musicality to die for. All the Daedalus dual tweeter designs suffer from the same issues as the Ulysses - just a bit too much top end energy.
geeze.I'm looking at your gear, your past gear, your set up, your treatments, and I bet it sounds incredible. Probably better than 99.95% of the systems out there, or at least for my taste. Maybe go listen to some other systems and come back to appreciate how the many strengths of your system really out weigh the weakness.
