Jon,Felt the whole front of the speaker (black part or at least around the tweeter) and cut off the phase guide on the tweeter. Way less bright, focused and clear.
what caused the brightness? the stereophile measurements didnt suggest that at all. except the ringing at 20khz, which it won't be remedied by removing the guide.http://www.stereophile.com/content/revel-performa-m20-loudspeaker-measurements-part-2
Measurements don't tell the whole story, obviously. Most of the brightness went away with these upgrades, with just a trace remaining. Atkinson noted that he also felt there was a discontinuity between woofer and tweeter, although it doesn't show in the measurements. I think the psychoacoustic effect of the mismatch in tonality is manifest as brightness in this case. Tightening the focus on the lows and midrange by absorbing more of the rear wave using the No-rez, and smoothing the tweeter with the improved cap allows them to blend better, which the ear/brain "likes" better. That's how I hear it, anyway.In any case, I'm very pleased with the outcome.
Sonicaps are a great bargain but they do have a thinner presentation IMO. For a little warmer upper midrange/treble good affordable options are ClarityCap ESA or Audyn Cap Plus.
I thought this was an interesting comment. Just picked up the Revel M20's and they certainly are fatiguing after a long listen - even with the tweeter attenuation all the way down. If cutting off the phase guide is a quick fix, I'd do it in a heartbeat but I'd love more confirmation that this is a good idea first. Any thoughts guys?
This thread could use some pics!!!
Hi Jonbee, I’m a new member and I have 2 pairs of m20 need to upgrade but I’m not that much of a DIY kinda guy. So do you do this on the side? I willingly to pay for all the parts, labor and shipping. thank you in advance
