0 Members and 1 Guest are viewing this topic. Read 14349 times.
Link ...?
I had 1.7s and 4 days ago the 3.7i's that I bought used arrived. These were shipped here from the factory after the upgrade. Nothing else has changed and now the volume settings need to be quite a lot higher to get the same levels. Amp is a Sanders Magtech (a different amp from when you were here Davey). And I can't get the soundstage depth from before. Lots of great detail, tonality is really nice, but the speakers just don't disappear. Any ideas as to what, if anything, might be wrong? Jeff
Charles,It sounds like Jeff bought these used. No break in should be required.Capacitor forming? Nonsense. These are new capacitors that are not electrolytics and this is an AC signal circuit.Jeff,I'm assuming you started with the speakers in the same position as your 1.7's and with tweeters in the same orientation? Your room is big enough so you certainly should be able to obtain the same soundstage depth as with the 1.7's. If you changed amplifiers when you changed speakers I could understand a different volume control setting as voltage gain may have changed. The 1.7 and 3.7 are listed as exactly the same sensitivity so I wouldn't think large volume control changes would be noticed if the rest of the equipment stayed the same.Cheers,Dave.
Charles,I suggest to Google capacitor forming and do some reading on the topic.I'm well aware of what it is and have done my share of reforming capacitors. I cut my teeth on repairing old radios and TV's when I got started in electronics about forty years ago.Regardless, Jeff was told that possible component changes might require break-in, "but not in this case." So I guess capacitor forming (real or perceived) is not an issue in this situation. Or maybe Jeff was lied to on the telephone? Dave.
