Audio/Video Gear and Systems
(Moderators:
JohnR
Blackmore
speaker placement ??'s
marvda1
freelance reviewer: The Sound Advocate
21 Sep 2004, 10:54 pm »
1. to place speaker out into the room do you measure from the front of the speaker or rear? does it make a difference if it is rear or front ported?
2. for side placement do you measure from side of speaker to wall or center of drivers to wall?
3. distance apart is measured from inside speaker cabinet to cabinet or center of driver to center of driver?
thanks
marvin
mcgsxr
Mark in Burlington, Canada
21 Sep 2004, 11:46 pm »
Well, I measure from the wall to the closest edge - so from the rear wall, to the rear edge of the cabinet.
I am sure that others might measure differently, but either way will get you right in the correct neighborhood.
Mark
R_burke
Reply #2 on:
22 Sep 2004, 12:02 am »
I use
1. Front
2. Closest side
3. Center of driver
Don't think there is an exact correct way
Inscrutable
Reply #3 on:
22 Sep 2004, 10:25 am »
I use the front/center of the drivers in all cases
(Moderators:
JohnR
Blackmore
