VPI Classic with Audio Technica AT150MLX MM
0 Members and 1 Guest are viewing this topic. Read 1678 times.
SteveRB
« on: 11 Feb 2015, 11:07 pm »
After a long break in period, including cable and tube changes, the VPI Classic with Audio Technica AT150MLX MM is an excellent combination.
Wayner
Re: VPI Classic with Audio Technica AT150MLX MM
« Reply #1 on: 11 Feb 2015, 11:54 pm »
What phono pre are you using, if I might ask?
Wayner
SteveRB
« Reply #2 on: 11 Feb 2015, 11:58 pm »
Leben RS-30EQ
The cart tracks very well on the unipivot arm. The high end was like glass for the first 50-60 hours. Really mellowed out after a while.
SteveRB
« Reply #3 on: 26 Mar 2015, 02:02 am »
UPDATE.
This is a great cart for the stock VPI Classic: it really sounds great fully broke in now. And very affordable.
Requires a careful set up (but really what doesn't) good thing there is a step by step guid...
http://dagogo.com/audio-technica-at150mlx-dual-moving-magnet-cartridge-review...
I have all tube amplification and custom Belle Klipsch. But at this price it's worth a go with your Classic.
