0 Members and 1 Guest are viewing this topic. Read 13057 times.
....1k for now but would be happy to invest more over time. In a way spending 4k on speakers and driving them with a $500 amp doesnt fully make sense. On the other hand I have always read that most of the budget should go to speakers. So... I am confused....
I have never owned a receiver where you could use its amps with a different pre .
Any receiver with HDMI input can use its amps with a different pre. For example you can use the Oppo BDP-105 as the pre for decoding, levels, distance settings, etc. with the amp section of just about any receiver. Many also do this with their HTPC to a receiver. The pre just needs HDMI output.
What source are you using would help, also if it is stereo or multi-channel?Are you running with Audyssey engaged on the 4311? If so, you may want to dry the "Bypass Left/Right" setting. There are a lot of tricks to get a good calibration with Audyssey.Also for music, make sure the "Dynamic Volume" setting is disabled. That will really mess up your bass response.
[Any thoughts? Any way to test a reasonable amp? Anyone here in San Antonio Thanks,MaxI am in San Antonio. Jim built me some sweet SCSTs. Really good with my PrimaLuna.Nick
I have the 4311 which I use as a preamp with a Boston Acoustics A7200 amp. The A7200 is a clone of the Sherwood A-965 which is an excellent amp for the money IMO. I also have a Parasound 2100 preamp that has HT Bypass. I listen to two channel music with the 2100 and multichannel music with the 4311. I have a pair of Wyred 4 Sound MX-500 mono-block amps coming this week. I'm really looking forward to how those will sound compared to the A7200. The MX-500s will be used for the R front and L front speakers and have more than double the power of the A7200 .http://www.bostonacoustics.com/CA/Product/Pages/ProductDetail.aspx?IsDisc=1&Pid=A7200(BostonAcoustics)http://www.audioreview.com/cat/amplification/amplifiers/sherwood-newcastle/a-965/prd_334332_1583crx.aspxhttps://www.parasound.com/nc/2100.phphttps://wyred4sound.com/products/mono/sx-seriesBill
Sounds awesome bill, with the 4311ci amps, did you feel like you where missing detail and clarity? When you pair it up with one of your amps, what can you immediately notice? What type of music do you listen to!Thanks
