Which 52mm Circular Polarizer?
chip
« on: 9 Feb 2015, 05:18 pm »
Looking to purchase a 52mm Circular Polarizer for my FZ150 camera. Don't know much about these and have done some reading. Looks like Hoya, Tiffen are some recommended names. I want something decent to try but don't want to spend more than like $50.....
This one seems like a decent one - Hoya 52mm Circular Polarizer HD Hardened Glass 8-layer Multi-Coated Filter ($49) and than one like this Hoya 52mm Circular Polarizing Glass Filter - B52CRPLGB ($30).
I also see some that are coated and some not.
Any suggestions would be great!
thunderbrick
  • I'm just not right!
Re: Which 52mm Circular Polarizer?
« Reply #1 on: 9 Feb 2015, 06:05 pm »
You might buy a thin POL filter that has a shallower ring and won't vignette on your images on wide angle settings.
chip
« Reply #2 on: 9 Feb 2015, 06:20 pm »
Also this one -  B+W 52mm Circular Polarizer MRC Filter for $64
thunderbrick
« Reply #3 on: 9 Feb 2015, 06:21 pm »
+1!
Bob2
« Reply #4 on: 9 Feb 2015, 06:30 pm »
+2
chip
« Reply #5 on: 9 Feb 2015, 06:45 pm »
So you mentioned to look for slim ones:
For $80  B+W 52mm Circular Polarizer Slim MRC Filter
For $40  Sigma 52mm DG Multi-Layer Coated Wide Circular Polarizer Filter
For $53  B+W 52mm Circular Polarizer Slim Filter but doesn't look like it has multicoating.
chip
« Reply #6 on: 11 Feb 2015, 08:21 pm »
For now I went with the Sigma SICPMC52W 52mm DG Multi-Layer Coated Wide Circular Polarizer Filter .
gnuyork
« Reply #7 on: 15 Feb 2015, 08:51 pm »
I use a b+W. I read they make some of the best, but I haven't tried anything else. Somewhere online I saw a review with images that steered more towards the B+W.
I'm half considering getting a Lee filter holder system for using graduated ND filters.
chip
« Reply #8 on: 19 Feb 2015, 04:04 pm »
B&W do seem to top notch for price range.
