0 Members and 1 Guest are viewing this topic. Read 7345 times.
http://www.elserw.com.pl/baza/PDFy/YDA138.pdfFX are initials producer ampboard
There is a section on First Stage Amplifier Gain Setting Function on page 6. Not exactly sure what it means though in response to your question.
Seems the gain are the L1 L2 L3 L4 blue K220, two per channel.
The PCB description say: Built-in 4 groups Gain Mode, can adapt to different sources.Which seems an auto gain setting inside the chip, not a manual control gain.
And doublej pointed correctly to the chips datasheet that states gain control is set by 2 pins
for this novice, is there a switch of some sort ?
No, no switch.You'd have to identify pins 26 & 27, see how they are connected now and then make a decision on if you'd want to change the settings.You could add a switch.Both require some experience with smd soldering.So, not for the novice I'm afraid.
