adding a sub Vandersteen method--"HIGH-PASS OF THE MAIN SPEAKERS"
0 Members and 1 Guest are viewing this topic. Read 9823 times.
ctsooner
Guys, I read that about midrange needing a ton of current during difficult passages on his site.  Let me see what I can come up with as that thread is long long long.  I'll post what I can.
ctsooner
Ok, here is a bit more in depth response:
Music is mostly transients.  So peak voltage is often in the midrange.  When a amplifier is delivering current to woofers that are normally lower in impedance and therefore peak current increases and the power supply rails drop 10 - 15 %.  Removing the current demands of driving the woofer with a high-pass allows the rails to remain at a higher voltage allowing higher voltage peak in the mids which minimizes clipping.  Impedance of most speakers is higher in the mids than woofer frequencies.
Using the sub and high-pass helps.  Some however, take this too far as piano transients especially, can clip an amp, which is mostlly voltage as the impedance is apx 8 ohms on the Model 3 and the woofer below 4 ohms.
I hope this clears up what I was trying to state earlier in this thread.  Thanks.
