0 Members and 1 Guest are viewing this topic. Read 10052 times.
This 3 video set will show a useful understanding from tubes working to the OP.https://www.youtube.com/watch?v=UM3av6moJd4
Hi FullRangeMan,thanks for the link, lots of good stuff there...Guy 13
hi guyyeah it tells how tube works in kindergarden terms,sorry i had to say this...
. . . might be a little too advance for the average Audio Circle members.
Hi Mr. Georgopoulos,nice to know that you are a knowledgeable personwhen it comes to tubes (Design), but I think what FullRangeMan was trying to do, its just let us know about basic of tube.The formulas that you have shown us, might be a little too advance for the average Audio Circle members. But by showing us what you know and sharing with us your knowledge on tubes is a good idea. Just wanted top let you know.Guy 13
Just on the tube topic.....Watched a great video on the Mullard factory...https://www.youtube.com/watch?v=GDvF89Bh27Yand this cool little video on different tubes being tested https://www.youtube.com/watch?v=Kf1MGEOQXZQI have purchased a tube amp but am waiting to run a dedicated circuit to run it from before using it.....It requires matched quads...I purchased some psvanes 6ca7-t2Svetlana el34 and it came withMullard el34sSo I am a bit excited.....It's an electrostatic headphone rig Again I appreciate now having a basic understanding of Bias and Amp rating in regards to tubes!I am sure after I have burnt all these things in I will be on the hunt for some old school tubes to try...
Just reread George's post...So is it a tubes impedance that affects it's ability to reproduce the signal when amplifying?Hence the different "colouring" each tube design provides?And can I assume its the different materials and plate shapes that create the differing impedances?or am I way off Thanks againBen
You right. There is some hi impedances tubes that have great sound, as 211, 805, GM70 etcAnd some low impedances tubes that also have great sound as EL34.
