0 Members and 1 Guest are viewing this topic. Read 9817 times.
current drive...no thanks...
Here's Stereophile's impedance and phase measurements of the Dunlavy SC-IV/A. A sealed critically damped system Fig.1 Dunlavy SC-IV/A, electrical impedance (solid) and phase (dashed) (2 ohms/vertical div.). As you can see from the graph there appears to be a maximum worst case impedance rise of 3 ohms at the bass resonance frequency.A higher system Qts with the associated impedance rise resulting from a higher driver Qts could be easily be reduced to the same magnitude or lower by using an aperiodic vent. The system Qts could be about .5 with reasonable bass extension if the driver Qts allows it. If good bass extension can not be achieved with an aperiodic alignment, then an aperiodic alignment can still be used and the bass supplemented with an added sub-woofer. Scotty
Current source amps are interesting, but the problem is, the vast majority of driver/transducers on the market are not suitable for this type of source.
