Tube Pre Amp Thoughts
0 Members and 1 Guest are viewing this topic. Read 5305 times.
Mad DOg
« Reply #20 on: 21 Sep 2004, 12:30 am »
Quote from: Jon L
Eastern Audio Minimax pre can be bought near that price as well and good sounding.
yeah, but it doesn't have a remote control...
doug s.
  • makin' music
« Reply #21 on: 21 Sep 2004, 12:42 am »
i'd look for a melos sha-gold-r - stock or modded by m.a.r.
a dealer who carried audible illusions recommended the melos to me even tho he dint carry them, when i told him i was considering a used melos a while back.  he also recommended it over cary & rogue, which he also carried.  the sha-gold-r is a simpler wersion of the ma333r i presently own.  and my pre absolutely blew away the rogue magnum 99 & cary slp-98 i owned prior...
doug s.
Lost81
« Reply #22 on: 21 Sep 2004, 01:03 am »
Hi Mark,
Keep a lookout for the Audible Illusions L1 Pre-amplifier.
Sometimes you get lucky and see used ones going for $600 on Audiogon.
They use two 6922 tubes.
They are really open and "airy" (some say too airy).
One just went for $540...
-Lost81
Inscrutable
    • http://home.earthlink.net/~inscrutabl/index.html
« Reply #23 on: 22 Sep 2004, 10:51 am »
You can probably find a used Rogue 66 near your price point.  They come with EITHER a remote OR phono stage, and while most are silver face, there are black faces out there.
DTB300
« Reply #24 on: 22 Sep 2004, 12:06 pm »
I know this is a little over your budget (do I sound like a typical SS salesperson or what?), but it does fit your requirements and it is being sold used on Audiogon...link below.
I own one and have been very happy with it.
http://cls.audiogon.com/cgi-bin/cls.pl?preatube&1099444880
PhilNYC
« Reply #25 on: 22 Sep 2004, 12:57 pm »
Quote from: Jay S
Also check out the AE-3 preamp... I forget the name of the company (AES?) but it is related to Cary and the preamp is designed by Dennis J Had (founder of Cary).  You should get a great buy on a used one.
FWIW, if this one is of interest to you, I know someone who is selling his....
mcgsxr
« Reply #26 on: 22 Sep 2004, 05:01 pm »
Thanks so much for expanding my search, AS I save the money.  It is great that there are options out there, and as I get closer to pulling the trigger, I will be able to have multiple targets to hunt.
Wayne, good point about the Audcom, and I assume that the modifications that you offer can help in this regard...
Mark in Canada
