KCI, Kool Cables, Inc. Pegasus digital, 1.25m RCA to BNC with upgraded terminati
0 Members and 1 Guest are viewing this topic. Read 815 times.
budburma
Brand spanking new, never used.  I bought this for a system that didn't come together and I've decided to go with a one box DAC/CDP.  This cable is masterfully constructed by a very talented designer with upgraded Xhadows fantastic sounding RCA and Vampire BNC.  Treated on Audiodharma cable cooker pro  and then treated with WALKER SST extreme. From the website:
Using a proprietary build/treatment process the signal and return conductors are produced from pure, 99.998% 24K gold bullion and pure 99.999% pure German silver which is melted down and pulled into a individual fine audio grade wires using a special Pat. Pending process. This process dramatically helps reduce the dreaded "skin effect" as well as keeping jitter in check. Each wire is treated with our proprietary cleaning, polishing and preservation process, pulled through an over sized pure Teflon tube and wrapped in pure chemical free virgin silk. This entire assembly is then sealed in a special covering that is impregnated with an RFI blocking agent and finally covered with our higher grade of Tech flex* type material acting as a protective covering. One aspect that is most often overlooked yet is still extremely important is a cables strain relief system. Using a heat molding technique with carbon fiber reinforcement we have developed a new and much improved strain relief system that is extremely durable and rugged giving you, the customer, piece of mind knowing that your cables are built to last!
Weight, Size, Flexibility
With a weight coming in at under 8 ounces and a bend radius of less than 2.0 inches the Pegasus is a cable that defines manageability! The Pegasus will easily integrate into your system, no worries about Anaconda sized cables that weigh 10 pounds, bend RCA jacks and have no concept of the word flexibility.
Thanks for looking.
Read my feedback and buy with confidence.
USPS money orders gladly accepted.  Paypal 3% fee to the buyer.
Shipping is on me.
Happy Holidays and enjoy the tunes!
grey9hound
budburma
 :duh: That's an oversight.....
$375.  ($540 from KCI)
I also have a Revelation Audio Labs Prophecy Reference same length and set-up
$325.  ($475 from RAL)
