Recommendation to lower noise floor with tubes and horns
0 Members and 1 Guest are viewing this topic. Read 8082 times.
SteveRB
Re: Recommendation to lower noise floor with tubes and horns
« Reply #20 on: 20 Jan 2015, 06:08 pm »
The spec on my current MM output is 3.5 not 6.5 as stated above...
SteveRB
« Reply #21 on: 20 Jan 2015, 06:33 pm »
A new MC and SU is pushing $2000. That's a bit much for this year. I do have a Denon 103 and vintage SU I could try out as well, but that guy doesn't always mate well with the uni-pivot arm.
SteveRB
« Reply #22 on: 21 Jan 2015, 01:16 am »
Ok, Back to the phono stage gain (I started a new conversation in the Vinyl Circle)
BUT , I did find a Stereophile article with measurements which they say off the bat "The RS-30EQ phono preamplifier offered a voltage gain of 37.1dB, which is very much higher than the specified 23.5dB but is appropriate for moving-magnet cartridges."
http://www.stereophile.com/content/leben-rs-30eq-phono-preamplifier-measurements
So, I guess that ends that speculation...
vortrex
« Reply #23 on: 21 Jan 2015, 01:30 am »
Not my experience at all.  I had a system with too much gain (and noise) and installing the Leben resolved that.  It was significantly lower in gain (with 26db SUT connected) than the Zesto it replaced.  If that reviewer is correct I would have had even more gain!  Definitely was not evident by my volume knob.
SteveRB
« Reply #24 on: 21 Jan 2015, 03:46 am »
Interesting observations.
I find my volume knob is pretty consistent as well. I'm sure the efficiency of the horns is helping. But I believe that the Leben putting out closer to 35 db is a bit more realistic.
SteveRB
« Reply #25 on: 29 Jan 2015, 05:59 pm »
So I tried a new MM cart: AT 150MLX.
Sounds great BUT there is a ton of RF noise with this cart. ... A LOT of RF !!!
Any suggestions now?
