How about a DHT output DIY DAC?
0 Members and 1 Guest are viewing this topic. Read 7647 times.
randytsuch
Re: How about a DHT output DIY DAC?
« Reply #20 on: 13 Jan 2015, 10:52 pm »
I think he still has it,
http://www.bentaudio.com/index2.html  and then click on   "AVC-1 Slagleformer Package" on the left under Stuff
Or is this not what you used?
JoshK
« Reply #21 on: 13 Jan 2015, 11:07 pm »
That looks to be it.  Mine and I suspect Magz's are the large chassis (extra depth for active stages install) not the standard.
Mags
« Reply #22 on: 14 Jan 2015, 03:53 am »
Mags
« Reply #23 on: 14 Jan 2015, 03:55 am »
I'm using a different chassis from that one. Mine was from Front Panel Express.
poseidonsvoice
    • 2 channel/7 channel setup
« Reply #24 on: 8 Feb 2015, 09:08 pm »
Phenomenal build wowza!
Best,
Anand.
tronan
« Reply #25 on: 21 Mar 2015, 06:38 pm »
Did the shock mounting on the 26 tubes reduce/eliminate microphonics in the preamp?
Mags
« Reply #26 on: 6 Apr 2015, 05:33 pm »
I can detect no microphonics whatsoever. Sound is very clear from low to high volume, bluegrass to Metallica. Of course, if you tap on the tubes while it's running, you'll hear something (in addition to me screaming at you to stop tapping on my tubes!).
