Gain in Mosfet amp and suitable speakers for the 2 different volume controls
kumasan
Having 99 db/w speakers I often run into problems with the volume control being too sensitive. Among other things I have a transformer based passive pre amp with a max attenuation of 48 db and an amp with 36 db of gain and this is getting way too loud even in the first step of the attenuator giving me a total of 36-48 = -12 db.
1) What is the gain of the Mosfet amp?
2) What max. speaker sensivity do you recommend for the two volume controls available?
Vinnie R.
    • http://www.vinnierossi.com
Hi kumasan,
Welcome to Audiocircle and the Vinnie Rossi forum!
You certainly have A LOT of gain for 99dB speakers, and not enough attenuation.
LIO RVC's max attenuation (besides MUTE) is -63dB, with 64 steps.
LIO AVC's max attenuation (besides MUTE) is -54dB, with 64 steps.
As for your questions:
1) approx. 27dB
2) For either, you'll be fine with speakers with a sensitivity > 100dB.  But with such speakers, 36dB is too much gain on the power amp, in my opinion.
With LIO, I do not believe you'll have a problem with the volume being too loud on the first few steps - even with speakers > 100dB.
Best regards,
Vinnie
