The best $25 I've ever spent
vortrex
« on: 2 Jan 2015, 09:48 pm »
If you are doing drywall, get this.  No dust at all!  I cannot believe how well it works.  My lungs wish I would have got this long ago.
http://www.amazon.com/dp/B00097D2K4/ref=sr_ph?ie=UTF8&qid=1420235128
thunderbrick
  • I'm just not right!
Re: The best $25 I've ever spent
« Reply #1 on: 2 Jan 2015, 09:50 pm »
Yeah, but be sure to put a drywall filter in your ShopVac. And clean it frequently.
vortrex
« Reply #2 on: 2 Jan 2015, 10:08 pm »
Yes, use the fine inlet filter.  I also use a bag inside the shop vac and an exhaust filter.
jtwrace
    • TIPP YouTube Channel
« Reply #3 on: 2 Jan 2015, 10:22 pm »
Don't forget hearing protection from that shopvac!   ;)
Atlplasma
  • Just off the boat
« Reply #4 on: 2 Jan 2015, 11:33 pm »
WHAT!  :lol:
Atlplasma
  • Just off the boat
« Reply #5 on: 2 Jan 2015, 11:35 pm »
Seriously though, those things are loud. Wet sanding is also a good idea if you are doing drywall.
rodge827
« Reply #6 on: 2 Jan 2015, 11:46 pm »
Sponges are a great way to smooth off the rough edges on a final coat.
Not to wet and go lightly, after time you'll can get a hang of it.
Bob in St. Louis
« Reply #7 on: 3 Jan 2015, 02:50 am »
I wish I'd have known about that when I built this house 14 years ago.  :duh:
Although....I have a nice selection of free buckets as a result of all the 'mud' I used building it.
Neat product though.
