0 Members and 1 Guest are viewing this topic. Read 27181 times.
I am always surprised when theory trumps actual listening. Like the old saw about 'source' HAS TO BE best since it is the source.Naaah. Now it is true the source has to be good enough... (so it does not sound like vomit) but best? no way.I have no 'proof' I am more right than the folks who claim the source has to be best. But then we are all independent Human beings with our own axes to grind.But my personal system uses several $40 or so from eBay, used (originally $600 to $700) CD changers to a used $250 DAC.In comparison I just spent $5,000 on three sets of IC.Now to a 'source is most important' person, my actions are insane. But not to me, nor to my system.Just saying'.. Source is not the "MOST" important.IMO a thread about 'How much to spend' on each would be more useful.. But that is not this thread.Back in the pre 'high end' era..(1950's 1960's) the common saw was to spend 50% on speakers.. not anymore...
Werd,Except that the "source" is not really the source. The real source would be the original performance experienced at that time.......one time."Plays the band" is just nonsense. The band actually playing is the source.This is the type of "AC logic" I was referring to with my post that got deleted.This query to the topic of this thread was answered fairly successfully in Post #1. In your domestic reproduction chain, the speakers are the weakest link and, by definition, the most important. No other component imparts an audible signature to your experience as much as speakers do.This is a basic concept easily experienced. I'm surprised there are differing opinions on this.Good golly.Dave.
Elizabeth when you are listening to music, what conponent do you think you are hearing? You are hearing the source component that has been switched to, adjusted in volume and amplified through your speakers. You are hearing the source piece amplified. You are not hearing the pre amp or amp or speakers. You are listening to the source component.
The recording is not a component. Its like qualifying the room as a component. The room is not a component. It is an environment.
However, the envelope (or whatever you want to call it) between cruddy and good in sources is much narrower than it is between cruddy and good in speakers. ... But if I switched between two different CD players (sources) it would not be nearly as obvious.Dave.
You're correct that the recording is not a component. (It didn't say it was.)If you have a cruddy set of speakers it doesn't matter how good your source is.......you're still listening to cruddy speakers.Now, before you turn that around and create a straw man, let me stipulate there are cruddy sources too.However, the envelope (or whatever you want to call it) between cruddy and good in sources is much narrower than it is between cruddy and good in speakers. If that's a premise you can't agree with, then we're destined to agree to disagree.I can listen to similar speakers from the same manufacturer (say Magnepan MMG's and Magnepan 3.6's) and immediately tell the difference. But if I switched between two different CD players (sources) it would not be nearly as obvious.Dave.
Elizabeth, its because you are confusing two different questions and looking for the same answer. Upgrading the lowest link is not going to answer component importance. Or what component is the most important. it is asking the question. What should i upgrade next? Which is different than asking what is the most important component. Only because it is asking the question for a personal situation. Which is always different than what somebody else needs/wants.
Agree. My experience with my $250 DAC used with the $40 eBay changers.. vs my Sony SCD777ES.. The two sounds are very close. A far bigger difference is due to my using the SCD777ES straight to my preamp, vs the DAC goes to a VAC Standard I use as a 'glorified tube buffer'/ The tubed VAC alters the sound more than the difference between the two digital players. (though I have found a big jump form other transports to my DAC. and that most changers SUCK!! as a transport. just sayin')I had even bought a far more expensive (and raved over in both TAS and Stereophile) DAC.. and discovered it to be exactly the same quality of sound as my old used $250 DAC. So I took back the new $$$ DAC for a refund. That was my wake up moment when I realized it would take a huge $$$$ expenditure to really meaningfully upgrade my digital front end. And for what? (the tiny improvement was just not cost effective to me. lateral vs big improvement??)Added: I have to say a problem with some upgrades is they did NOT fill the least good component gap. So the better new item was masked by some other not so great item in the chain. This is a big problem for upgrading.. And again.. finding the RIGHT component to upgrade (one's weakest link" is always a big challenge. Some lateral moves really are an upgrade.. you just cannot hear it due to masking by other junk you own..((So for folks who say source first?? How can you know anything about your quality of source if everything after it comparatively sucks??? Accepting it because someone ELSE said it was 'good'? Can you even answer this? Just curious))
Elizabeth, this is what the source does. The source drives the entire soundstage. It drives the preamp. Preamps and amps can not fix a lousy output from a dac (for eg). The dac will form a sinewave from its bit depth. 24 bit is best. You can not add resolution later on or fix timing errors with cabling. All this is meaningless until it becomes apparent the soundstage has no pace or rhythm. Or it sounds like there is no bass. This is because the source could not drive a pre amp (and there is more failed source gear than not). They cheaped out on its power supply or dacs. Its the start of all misery and it will never repair itself with cabling or power amps or speakers. All because the source was thought ... meh. System syngergy means nothing if your source is garbage. There is no synergy, who cares about synergy if the thing is paddling along upstream with no beats. Because that is what you will get. This is a fools topic since alot of people claim the synergy thing (it sounds good to them) but its failing at every indicator.
Werd,I'm fairly sure if you interviewed many audio professionals and many users across this industry, you'd find yourself in the minority regarding the source being the most important components.I suspect if you polled thousands of those folks regarding the most important component, speakers would receive the highest percentage.Does that tell you anything?Dave.
I don't think anything or anyone tells Werd anything. He marches to the beat of a different drummer.
As for cables, that's a tough one. I guess it comes down to this - is the $900 one saves with $100 cables vs. $1000 cables better spent in a $900 more expensive source, speaker, pre, amp? It probably depends on how far up the law of diminishing returns the rest of your system is.
