Why do boxed speakers dominate at the retail channel?
0 Members and 1 Guest are viewing this topic. Read 23052 times.
Re: Why do boxed speakers dominate at the retail channel?
« Reply #40 on: 31 Dec 2014, 11:20 pm »
Tyson:
Agree that the room acoustics is a large factor in playback sound quality.  Recommend reading Floyd E. Toole’s “Sound Reproduction” to learn more about room acoustics.
What’s an “AC”?
Not every speaker is designed for flat response in an anechoic chamber.
Don’t understand how “tweeter room wash” is addressed by O.B.
As a fan of O.B., please explain how even a 4 foot wide baffle can provide the dipole effect on a 60 Hz (20 foot long) sound wave.
JohnR
« Reply #41 on: 31 Dec 2014, 11:30 pm »
I think perhaps your intuition is leading you astray here, to understand it properly requires tackling a little OB theory. It's probably best addressed in the OB circle, but the short version is that at the sides of the baffle, the time delay between the front and rear waves is zero and hence they cancel, thus creating the dipole null. In front of the baffle, the time delay between the front and rear waves is non-zero, so they do not cancel; instead, the amount of cancellation progressively increases as frequency lowers below the frequency known as Feq - the result is a 6dB/octave reduction in SPL as frequency reduces (in free space). This time delay (and thus Feq) is determined by the geometry of the baffle but in the case of a flat baffle it's primarily the baffle width.
HTH :) Happy New Year!
« Last Edit: 1 Jan 2015, 12:45 am by JohnR »
Ultralight
« Reply #42 on: 1 Jan 2015, 07:08 am »
Happy New Year to all too.
Good reading all. Appreciate the posts and I'll undoubtedly go back and reread.  I do note that my original intent is to simply understand why box speakers dominate at the retail level.  It is not my intent to disparage one type of design over another - there is plenty of room for all kinds of approaches because the needs are so varied.   There is no one solution for all applications.
UL
« Reply #43 on: 1 Jan 2015, 11:53 am »
Note that dipole fans might put down drivers in boxes, yet most use boxed subwoofers to make bass/deep bass.  Surprised that I haven't read of any home owners here at AC using infinite baffles for subwoofers.  Requires a space >10 times driver Vas behind the mounting wall (and avoid closets/rooms with hinged doors that could blow the cone out if slammed - or just add slow action door closers).  Some use crawl or attic spaces.  Garages can work too.  Without box reinforcement it's not an efficient way to make bass, so often two to four 15 inch drivers are used.
Search for "The cult of the infinitely baffled".
JohnR
« Reply #44 on: 1 Jan 2015, 01:19 pm »
Well, I guess if you wanted to bring up something that is even harder to find in retail stores than OB speakers, IB would be it  :lol:
ebag4
« Reply #45 on: 1 Jan 2015, 02:39 pm »
No boxed subs required for my setup that consist of 2 12" servo subs in an "H" frame per channel.  Best bass I have heard and although it won't plummet do earth shaking frequencies like my IB setup does, it easily fills the room with bass goodness down to 20 Hz.  For music my servos are preferred over my 4 15" AE IB15's driven by 2400 watts in IB.
This may only apply to me, but ever since I lived with OB, I have been able to hear the box in boxed speakers.
JLM, if the OBs you have heard have a diffuse soundstage/imaging, you have not heard OBs set up correctly.
Best.
Ed
« Reply #46 on: 1 Jan 2015, 02:42 pm »
So I did a bit more research:  Linkwitz has good conclusions (a few that I disagree with); Martin J. King has a nice write up that explains O.B. bass - basically you need brute force (such as the "right" higher efficiency bass drivers/multiple such drivers/floor reinforcement/bigger baffles) to make it work (as I thought), but he seems to ignore sound quality versus simple frequency response making O.B. seem more doable than realistic; and an insightful professional review of the rather large and quite expensive/reportedly impressive Jamo R909; but as we've seen here on AC overall it's hard to find unbiased opinions on this topic.
I'm still confused as to why dipole designs that use discrete drivers almost universally use only a forward firing tweeter (while a few box speakers add a rear firing one to add "space/ambiance"), seemingly ignoring some of the basic premises of O.B.
My conclusion is that largely boils down to the old subjectivity of audiophiles tastes, in this case of imaging.
ebag4
« Reply #47 on: 1 Jan 2015, 02:46 pm »
You should listen to some servo subs in an "H" frame, your perception of what is doable in OB bass would change.
Davey
« Reply #48 on: 1 Jan 2015, 02:46 pm »
Actually, IB is a really good way to make bass......box reinforcement reduces efficiency, it doesn't improve it......relative to IB.  Your power amplifier doesn't have to work against the air spring within the box.
But John is right.......IB would be even more scarce than OB in retail (or even domestic) environment.  :)
Dave.
FireGuy
« Reply #49 on: 1 Jan 2015, 03:23 pm »
Dave.
Disadvantages to the IB? When a speaker is mounted in an enclosure, the air inside the enclosure acts like a spring against the speaker cone, and the resulting buildup in pressure provides mechanical damping and prevents excessive cone movement. But an IB installation does not use an enclosure, so the mechanical damping is poor, resulting in "hang-over" and lack of definition. The power handling of the speaker will also be compromised since the IB provides very little control over cone excursion.
Can someone explain how designers overcome the above?
Davey
« Reply #50 on: 1 Jan 2015, 03:30 pm »
I think you might be confused on what the work of Edgar Villchur entailed.
For the same driver and all other things being equal, if you make the box bigger you reduce the power requirement.  (This is a basic concept.)
The increased linearity of the restoring force in the acoustic suspension environment allowed alternative drivers (a key distinction/difference) to be utilized....drivers that were built with this usage in mind, ie, much looser suspension.
You have to select the correct driver for the application, whether that be IB or small box or OB.  Whichever direction you turn has trade-offs.
Of course, the primary disadvantage of IB is the probably very complicated implementation scheme.  You need a really big box.  :)  This might be an actual box or another room or maybe the outside world.
Dave.
PRELUDE
« Reply #51 on: 1 Jan 2015, 05:15 pm »
Hi folks,
First, happy new year to all and wish the best. :thumb:
I have been reading this post on and off since yesterday with interest while I am working around my house and feel like this discussion more likely a comparison between the designs rather then answering the OP.
Ultralight,
There are number of different type of speakers and always will. But there are different type of consumers with a great objective matters in their head as well. Not everyone buy the speaker for the sound. One might buy the most expensive one to impress his friends or the nice looking one or a small monitors because of his wife and lastly might be for sound.
You see more posts in OB circles, but if you look carefully you might be answer your own question that only 1% is a buyer and the rest are the DIYers or kit builders.
Would you build up a  retail business based on only 1% customer even though it is better?
Sometimes people look at the audio business like voodoo.  There is no difference between audio or anything else. No profit= No business and it does not matter what is good or bad.
If you want to find the truth, and see which one works the best for you, then try to make few speakers and compare them with each other and see what you think. Do not worry about the money you spend because you are educating yourself. If you go out there and buy the best speaker, you would still loose a big amount of money when you sell them any way.
Retail store would only sell you the ones that can make the most profit regardless it is good bad or however.
I would say if the retail stores are trying to sell you only the best and out performance gears then how about we stop selling all three way passive designs and replace them with active regardless of type of speaker?
Pete Schumacher
  • It's all in the pursuit
    • Vapor Audio
« Reply #52 on: 1 Jan 2015, 07:02 pm »
It's only when you're driving the speaker below its usable range that the air spring of an enclosure offers any benefit over cone motion.  Putting a driver into an infinite baffle would require you to limit the low frequency content being sent to the driver so that damage from over excursion is not a problem.  But "overhang" and "lack of definition" are not caused by the loss of an air spring.  Some of the best  bass I've ever heard was from an OB setup with very large woofers.
« Reply #53 on: 1 Jan 2015, 08:09 pm »
I actually know ThomasW, he is here in Denver.  He  helped me build my previous pair of speakers - great guy.  I got to hear the 12 shiva's dancing several times.  Servo OB bass is still quite a bit better.  IB simply does not address the issue of bass room modes at all.  But, if you ever get a chance to hear it, the amount of output is very, very impressive. Seriously, when the very low bass notes hits, it pressurized the room so thoroughly that it feels like you are under water.  Crazy!
Hi folks,
Ultralight,
Agreed, 3 way active OB is the way to go!  That's what I'm running, so it must be the best, right?  Amiright, amiright?  Hahah.  But it is true, passive crossovers do suck quite a bit of life out of speakers, particularly 3 way passives, at least compared to an active version of the same speaker.  I can see why actives are not more popular though - if customers can figure out ways to f'up the relatively bulletproof passive designs, then an active design is like handing a firearm to a child.  Aftermarket support would be a nightmare.
On a related note, I have a theory about why some people like single driver speakers so much.  And it has to do with some of the things we talked about here - one, a lack of a passive crossover is very helpful, but there is also the fact that the highs become very directional (similar to horn speakers and OB speakers), and they don't generally extend down in the bass region very far (causing less room mode nastiness).  So, why are these alternate approaches so appealing (horns, OB, single driver)?  Because they each in their own way deal with the biggest influence on quality of sound - the ROOM.
dukecv
« Reply #54 on: 1 Jan 2015, 08:24 pm »
From a newbie perspective I would probably think box speakers dominate in the sense that they are easiest to set up and offer the most benefits for the typical household. Not everyone has a theater. Nor a dedicated two channel listening room with all the proper treatments. A small box speaker w/port is higher on the WAF than a larger IB/OB design. At least it's that way with my wife. And I would "guess" that a box speaker with a crossover would cover the frequency spectrum better at higher volumes. And the fact that there are more box speaker designs available to me than any other would be a deciding factor for me.
Russell Dawkins
« Reply #55 on: 1 Jan 2015, 10:26 pm »
My take on the original question is that the box speaker, especially due to its smaller size which minimizes materials and shipping costs, is the cheapest way to make a speaker with a sound that is gratifying to the average buyer.
dukecv
« Reply #56 on: 1 Jan 2015, 11:11 pm »
Well said!
Freo-1
« Reply #57 on: 1 Jan 2015, 11:22 pm »
You also can get excellent results from a pair of sealed box monitors and augment with a subwoofer. In my secondary, audio only system, I'm using a pair of sealed box monitors (ATC SCM-19) with a matching sealed box subwoofer (ATC C1), providing full frequency response in a reasonably compact footprint.  Other types of speakers need to be in the right room environment to work correctly.  Its easier to get box speakers to work reasonably well in a wider variety of rooms.
DaveC113
  • ZenWaveAudio.com
« Reply #58 on: 1 Jan 2015, 11:26 pm »
I've heard great speakers of all kinds, there is more than one way to skin a cat!  :green:
On bass, I do prefer a simple bass reflex cabinet or TL with a 15" woofer, preferably front ported. I appreciate the dynamics this type of cabinet offers that I find lacking with OB bass. For the same reason I prefer a speaker that reaches deep enough that a sub is not a requirement.
« Reply #59 on: 1 Jan 2015, 11:59 pm »
Lack of box (or horn or pipe) back pressure is the same for open or infinite baffle, both simply require a different driver (higher Qt) to compensate.
30 years ago I had a pair of 6 cubic foot mass loaded transmission line cabinets each supporting a single 8 inch woofer.  I've heard a couple of big open/infinite baffle bass, no comparison - not even close.  And I agree that small sealed mains with subwoofer (if the back wave is designed to not reflect back out through the mid/woofer cone).
I agree that rooms are the silent killer of most audio and that some designs work better than others (I'd also include transmission lines in that list).
I don't agree that building boxes versus O.B. is the way to discover which is best.  Sawdust does not by itself equal enlightenment.  It takes good drivers (that aren't cheap) to make really good speakers, and the ideal drivers for boxes aren't the necessarily the same for panels, so then you'd be comparing apples to oranges.
Again, it boils down to individual tastes and preferences.  And unbiased opinions are hard to find (especially in this thread).
