What product types respond best to Uber power clean-up?
dburna
I currently have 9 components in my system:
(1) Mac Mini
(1) a-RT Legato USB-to-S/PDIF convertor
(1) Audio G-D DAC 19DSP (with 1704 DAC chip)
(1) Tortuga Audio DIY Passive Pre-amp
(1) NCore NC400 stereo amp
(3) WD hard drives
I looked on this Circle but didn't find any topics covering this question: which component types will typically respond best to clean(er) power?  Opinions (or experience) with the specific equipment above is great, but I am also in whether pre-amps/amps/CD players/etc. seem to respond best to the P.I. magic.
Thanks,  -dB
paul79
Re: What product types respond best to Uber power clean-up?
« Reply #1 on: 21 Dec 2014, 06:17 pm »
If it helps, everything I have plugged into the UberBUSS gets improved. Digital gear really thrives on clean power, so if I had to say what benefited the most, this would be it. No experience with Class D amps, but I assume they would also, if not even more so than any other type of amp.
mresseguie
« Reply #2 on: 21 Dec 2014, 06:31 pm »
DB,
I'll echo what Paul mentioned. Everything I plug into my UberBUSS benefits. My system is sooo quiet now. I can't say enough good things about it. Eventually, I will buy a second unit (probably the MajikBUSS) to use in a future system in Taiwan.
Michael
dBe
    • PI audio group, LLC
« Reply #3 on: 21 Dec 2014, 07:41 pm »
(1) Mac Mini
(3) WD hard drives
Thanks,  -dB
One of THE BIG LIES in audio is this one:  "Everything will benefit from the XYZ - it has to be heard to be believed".  I wish I could say that about the Uber, but it just ain't so.
Here is what the Uber does in a nutshell.  It provides a syenergistic match between incoming AC and transformers attached to the BUSS.  The operative word here is "transformers".  Ones that are basically just connected to the BUSS without a bunch of series resonant circuits between them - like most SMPS.  Linear power supplies are a great mach to the BUSS.  Some well designed SMPS likes the Uber, some other SMPS don't  What complicates everything is anecdotal evidence from customers whose experiences with some SMPS gear is opposite.
The 2 components I would say may work well, or may not are the Mac Mini and the nCore.  My Minis sound best straight into the wall when AC powered.  I had a very positive experience with Roger Nordens nCore amp when it was here.  Other nCore owners say huh-uh.
Probably jtwrace can answer this question best.
Everything else is a go, even wall warts for the HDD.  Put them on one extension and plug them into a single receptacle on the Uber.  Keeps their noise way down.
DaveBSC
« Reply #4 on: 23 Dec 2014, 11:29 pm »
What do you think of the idea of using a separate series type filter (Furman, Panamax etc) on the Mac Mini, HDDs, wall-warts, etc, and using the Uber on audio components with linear supplies? Or is the isolation between outlets on the Uber good enough for this not to be necessary?
My experience with power conditioning in general is that linear supplies benefit FAR more than switchers do, and the "benefit" you may get from plugging a switcher into a conditioner is to take the noise it dumps back into the line *away* from the other components. I've also found that series type filters that run the current through capacitors and inductors on a PCB choke amplifiers to death, even amps with very modest power draw like a 50 watt Naim NAIT. The so called "high-current" outlets on these filters are complete BS.
jparkhur
« Reply #5 on: 23 Dec 2014, 11:46 pm »
Why don't you plug the other outlets in to the uber?   I had great success with plugging hard drives, amps and such in to my buss.   Jp
dBe
« Reply #6 on: 24 Dec 2014, 06:28 am »
I'm a fan of what works.  If the budget allows only one conditioner using one receptacle for warts and other cheap power supplies works well.  If budget allows using an additional conditioner like the one you mentioned is great if , and this is a big IF, the attenuation slope of the filter is steep enough and has values applicable for audio use.  Many of these 'conditioners' don't provide useful attenuation lower than 100kHz.  If they are first order filters they could only be down 6-9dB which isn't much help with wall warts with a switching frequency of 200kHz.  Even second order filters provide little attenuation at 200kHz.  Remember, most of the smaller "line conditioners" use crappy ceramic caps to tame the noise from the MOVs in them.
I prefer to use smaller surplus isolation transformers like old Stancors for taming HDD SMPS.  They have very low bandwidth and that is exactly what is required.  The newer Topaz isoTX are good ones, too and can be found on eBay for very little $$$.
I am not a fan of CorCom filtered power inlets or modules.  Too many lower cost "power conditioners" use them or an adaptation of them - a recipe for decreased dynamics like you alluded to.
KR500
« Reply #7 on: 24 Dec 2014, 01:24 pm »
I paid an electrician to run a separate dedicated power  line to the wall outlet that my rack gets plugged into .
Upgraded the duplex outlet .
Then  added  a power conditioner
rogerdn
« Reply #8 on: 27 Dec 2014, 06:12 pm »
Oh YES Dave the NCore sounds great on the UBUSS, how about an AppleTv and/or Airport Express ?
jessearias
« Reply #9 on: 27 Dec 2014, 06:29 pm »
I use the Uber for my main video/stereo equipment. (Pre Amp, Amp, CD, Tuner, TV, DVD)  I use a Mini to supply my Golden Ear Tritons (built in sub amps) and Laptop (for internet streaming). That combination works well for the intended devices. I also have a dedicated power supply to my listening room with surge protection in the main panel.
dBe
« Reply #10 on: 27 Dec 2014, 06:54 pm »
I simply don't know about the Apple TV or Airport.  I don't have an Internet connection to my system.
Someone here has to know...
Quiet Earth
« Reply #11 on: 27 Dec 2014, 10:12 pm »
It sounds like the Uber would be a natural fit for a BPT ultra isolation transformer then. Has anyone here tried that combination?
Here's what I'm thinking.....
1. plug the Uber into the wall
2. plug the BPT isolation transformer into the Uber
3. plug all of my audio components (with linear power supplies) into the BPT.
Thoughts?
dBe
« Reply #12 on: 28 Dec 2014, 01:40 am »
Thoughts?
Kinda.  For a while I ran a 2.5KVA Topaz Ultra Isolation Transformer plugged into an Uber.  It sounded very good.  I found that the system was much more dynamic and as quiet using only the Uber or with the power amps plugged into the Uber and front end plugged into the Topaz that was then plugged into the Uber.
I still have the Topaz.  I guess I should sell it.
What power amp(s) are you using?
Quiet Earth
« Reply #13 on: 28 Dec 2014, 04:35 am »
My power amps are Audio Note Quests. They are 8 watt/ch single ended triode amps and each one draws approximately 100 watts from the wall with or without music playing. They don't appear to tax my isolation transformer in current draw because the BPT is rated for 15 amps (1800W) and the dedicated circuit is also 15 amps. They sound better to me when plugged into the transformer than plugged directly into the wall. Dynamics seem unaffected either way, just much quieter coming from the transformer.
Was thinking an uber might take it a step further.
dBe
« Reply #14 on: 28 Dec 2014, 05:05 am »
I would try it both ways because quiet is good.  The system I was referring to were Cary CAD572SE Mk II mono blocks and dynamics were better just with the Uber.  Dynamics come in several flavors: micro as well as macro.  It was a combo of the two for me.  Then again, their current draw was about 220W or twice yours.
Basically this is how I view audio - there are no sacred cows.  Once I figured out years ago that "conventional wisdom" was mostly not wise I decided to TRY everything I could.  I try every possible configuration.  "Right" is what sounds best.
groovybassist
« Reply #15 on: 2 Jan 2015, 11:16 pm »
I don't have a great understanding of this stuff and am wondering if the amp in the link below would benefit from the UberBUSS? It has class D modules, but uses a large toroid in it's power amp section. Thoughts?
I picked one up at a significant discount off retail and am in the process of breaking it in.  Thanks.
Mike
http://www.micromega-hifi.com/en/products/amplifiers/ia-400
Triode Pete
  • www.TriodeWireLabs.com
    • Triode Wire Labs - Affordable Audiophile Cables
« Reply #16 on: 3 Jan 2015, 12:32 am »
Based upon my experience with UBERs & SETs, my mono blocks always sounded better, with better dynamics using the UberBUSS. Also, I noticed a slight increase in gain, a good thing IMHO with SET amps. Dave E. said it was the Power Factor correction circuity that assisted in this phenomenon.
Definitely any transformer based gear will benefit from the "Cleansing Power of the Uber"... Dave - I think I just coined a "new trademark for you!!! LOL!  :lol:
My $0.02,
Pete
dBe
« Reply #17 on: 3 Jan 2015, 03:26 am »
Mike
Should work great. Mike  :thumb:
dburna
« Reply #18 on: 3 Jan 2015, 03:40 am »
So I have one follow up question to all the info. generously offered by the posters: would anyone in Chicagoland be willing to lend me an Uber (or other PI Audio Buss) for use in my own system for a short period of time, say a weekend?  Though I wish it was otherwise, I'm not in a position to purchase anything at present, but it would be great to know if I should be saving for this as my next step.....or working to upgrade my DAC.  I don't want to trouble Dave -- who is a great guy -- because any purchase I make is likely to be a ways off.
Thanks in advance,  -dB
P.S. I always take great care of equipment.
groovybassist
« Reply #19 on: 3 Jan 2015, 02:18 pm »
Dave:
Cool - thanks for your feedback. Will consider options as break-in goes on.
Mike
