0 Members and 1 Guest are viewing this topic. Read 28329 times.
There is a pair of M1's for sale in Tucson right now! Free shipping too.I know the seller, been to his house a few times to listen to these Spatial's. He's a good guy too.http://www.audiocircle.com/index.php?topic=136388.msg1450197#msg1450197Wayne
I assume Clayton still has the M1's available at twice the price for a reason - there must be a performance difference. I would assume it's in the "refinement" factor.
How would you characterize the M1's from what you've heard at his house?
Dynamic! The M1's are also revealing making it easy to hear differences in amps, pre-amps and even cables. The Line Magnetic 518 amp has a nice relaxed tube based sound and the Job 225 solid state amp increased the jump factor but with a cleaner more analytical sound. So even though the M1's are easy to drive with low power I would not skimp on quality or you will regret it.In my opinion the best sound I heard from the M1's was when we plugged in the Van Alstine Synergy 450 amp. The Synergy 450 doubles down into 4 ohms so we had 450 watts per channel, 900 watts total! The AVA Synergy line is solid state and has a slightly warm tube like quality which kept the Spacials from getting shouty, at a low volume the sound was practically identical to the 35w/channel AVA Ultravalve amp except for the bass. The Spacial M1 with the Synergy 450 was magic with bass that was subterranean, controlled and limitless no matter how loud the music got.Don't be afraid to raise them off the floor a little, they sound better higher up.Wayne
Thanks for the response Wayne!You guys going to RMAF this year? I'll be making my first trip and will be there all three days and hope Spatial will have the M1's. It would be cool if Clayton would show the Lumina series and see how they perform.
Emerald Physics OB's using Eminence Alphas and Betas. Nothing wrong with that as I've had great results with them as well. The Alpha with its high Qts is probably the most popular OB woofer around. http://www.6moons.com/audioreviews/emerald/1.html
...But then, while the specs look pretty similar between M1's and M3's, I assume Clayton still has the M1's available at twice the price for a reason - there must be a performance difference.
