0 Members and 1 Guest are viewing this topic. Read 6281 times.
Your turntable has an AC motor which runs in cycle. Therefore, speed cannot be adjusted.But 3% variation is acceptable. I believe human ears are not sensitive enough to detect that speed difference.
It's been so long since I had mine, so things are foggy. Can't one move the motor to the left just a tad to change speed? I keep thinking that's how we did it, but I could be way wrong. Can you try a new belt? I think I'll go with that answer before I get gonged....
I believe the apps are good. We've used them. I was only thinking strobe disc due to the Amadeus. Can't vouch for your app, however. You are incorrect about the Kuzma. One does indeed set speed by adjusting the motor position. Try the new belt but first move your motor if you can.
AC, an 1/8 of an inch can be huge for pitch variation. Get off your duff and experiment. Chop chop!Also, you should be able to easily source a belt from www.turntablebasics.com, just in time to still play those holiday classics.... Good luck and happy holidays.
